New Hardwood Stairs - Carpentry - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-22-2012, 08:57 PM   #16
Stairguy
Millertyme's Avatar
Rewards Points: 508
Mistake...start with 5/16" shims on the 3rd tread
Millertyme is offline   Reply With Quote
Old 07-22-2012, 09:06 PM   #17
Rewards Points: 53
My thoughts were add 1" to each step. Middle risers remain at 7-1/2". First tread height is bumped up to 7-1/2" (5-1/2" + 1" shim + 1" Tread). Top step will end up at 7-3/4" (9" - 1" shim - 1" Tread + 3/4" hardwood flooring). Is 1/4" variance within code in most areas?
I'm sold, risers first. The new treads are 11-1/2" deep, stringer tread cut-outs are approx 9-1/2".
So buy a 2X10 of something and cut 1" shims? I would assume I want the shims to be the full length of the stringer cut-outs, correct?
smrf1080 is offline   Reply With Quote
Old 07-22-2012, 09:16 PM   #18
Stairguy
Millertyme's Avatar
Rewards Points: 508
Sorry disregard those two previous posts the info is incorrect.
You need to start at the bottom, and gradually make the shims larger as you go up. You need to gain 1-1/4" at the top. If you target a 7-1/2" rise and you add a 1" shim to the first tread, then you can add 1/16" to each shim as you go up and you should be fine.so second shim will be 1-1/16",third shim will be 1-1/8" and so on till you reach the top
Old 07-22-2012, 09:27 PM   #19
Stairguy
Millertyme's Avatar
Rewards Points: 508
Yes, I would rip them out of any 2x stock. Yes, always riser first. Treads will be ripped to 10-3/4" which will leave 1-1/4" overhang.make sure the risers are straight, so when the treads butt them there will be no gap. Keep a straight edge handy. You can easily shim the risers from the back before treads are installed. If the three stringers are not all in line there could be a lot of shimming.
I usually run the risers to the drywall before putting in the skirt. The skirt is cut to the face of each riser and the to the bottom of each tread. Doing it this way allows you to shim the riser from behind to pull it tight to the skirt, as opposed to just butting into it.
Old 07-22-2012, 09:57 PM   #20
Rewards Points: 53
It would be ok to make them all 1", and have the top step a 1/4" taller right?
Don't I need to rip the treads at 10" (this accounts for the 3/4" riser)?
Interesting idea with the skirt board. Seems like more work, but will have to think about that one.
Old 07-22-2012, 10:23 PM   #21
Ole Wood Worker
BigJim's Avatar
Rewards Points: 540
But there is a riser at the back of the tread and another under the front edge of the tread which will take up an additional 3/4 inch of over hang. If you subtract 3/4 at the back of the tread cut and an add 3/4 inch back at the front you still have the same length, you are taking 3/4 inch away then adding it back.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
Old 07-22-2012, 10:35 PM   #22
Rewards Points: 53
Ahh Yes, of course. Thanks all for the help.
Hardwood or Carpet on Stairs? RugbyLove Flooring 3 11-16-2011 03:19 PM
Transition of Hardwood Flooring on Stairs rkirby Flooring 1 02-02-2011 06:06 PM
Hardwood Stairs warnerww Flooring 9 04-24-2010 07:56 AM
Hardwood & Stairs budcam Flooring 4 09-15-2009 11:12 PM
Need to carpet hardwood stairs clasek Flooring 7 04-21-2009 11:00 AM
