New Entry Door - Carpentry - DIY Chatroom Home Improvement Forum
Old 09-01-2010, 04:39 PM   #1
New entry door
Hi I'm looking in to putting in a new front door and it measures 34"or 2'10". The R.O. is 36" to jack stud to jack stud . went to home depot and a 34" door is a special order ($150 more). I live in mass and the code is 36" for entry doors. Can I just put in a 34" door by code so wont have to reframe RO or mess with the horse hair plaster around the door?
Boston Bean is offline   Reply With Quote
Old 09-01-2010, 05:11 PM   #2
Old School
Willie T's Avatar
You have a code to follow that requires a 36" door, and you want to know if "by code" you can put in only a 32"?
Willie T
Old 09-01-2010, 05:24 PM   #3
Rewards Points: 50
Assuming your 32 is a typo,check with your building dept. to see if your 34" door might be grandfathered.
daveb1 is offline   Reply With Quote
The Following User Says Thank You to daveb1 For This Useful Post:
Boston Bean (09-01-2010)
Old 09-01-2010, 05:28 PM   #4
No what I'm saying it that is 36 code for new installs and I can replace with a 34
. Thanks
Old 09-01-2010, 05:33 PM   #5
Tom Struble's Avatar
Rewards Points: 2,002
wouldn't that be a ''new'' install?
Tom Struble is offline   Reply With Quote
Old 09-01-2010, 06:15 PM   #6
Rewards Points: 50
One could argue replacing like for like is not new or renovation but the inspector gets the final say.
Old 09-01-2010, 07:01 PM   #7
oh right i missed the existing door is 34'' thanks
Old 09-02-2010, 11:13 PM   #8
Registered User
Rewards Points: 526
As Dave said, check with B.D. for egress. One door to/from building needs to meet egress, not always the front door. Bedrooms require separate egress.
“Doors & Landings
o Door with direct access to exterior req’d
(not through garage) …………………………….………. [311.4.1]
o Min one exit 3ft wide x 6ft 8in high side-hinged door.
[311.4.2]
o All doors req keyless operation from interior….………. [311.4.4]
o Hallways min 36in wide…………………………………..
[311.3]
o Floor or landing each side of all exterior doors EXC…. [311.4.3]
2 risers OK at exterior door that is not req’d exit……… [311.4.3x]
o Floor or landing [at required exit] max 1½ in bellow
threshold EXC………………………………………….... [311.4.3]
Landing [7¾ in below threshold] OK if door does not
swing over landing.(screen door may swing over)….... [311.4.3x]
o Landing min 36in deep x width of door………………… [311.4.3]
o Exit balconies req positive attachment (lag screws not toe
nails) to resist lateral and vertical forces………………. [311.2.1] “ From: http://orangecountyva.gov/forms/EMER...QUIREMENTS.pdf
Ask them if a patio door will substitute….. Plus, you need an egress/ingress path with lighting.
Gary
Old 09-03-2010, 12:08 PM   #9
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,374
I'm sure your 34" door is grandfathered in. Check with your building department. Unless they're complete douchebags, they're not going to make you reframe.
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 09-08-2010, 10:02 AM   #10
thanks for all the help
Adjusting Garage Door torsion springs INGunGuy Building & Construction 4 10-12-2009 07:22 AM
Entry Door installation... Advice needed! mburgess44 General DIY Discussions 19 09-12-2009 07:46 PM
Larson Storm Door Won't Close Snowbird Building & Construction 13 03-03-2009 03:01 AM
Installing steel entry door NoExperience Carpentry 2 10-23-2008 11:23 AM
Prehung entry door gap problem 1fstws6 Building & Construction 3 03-21-2008 07:45 PM
