New Drawers Not Shutting Properly.... - Carpentry - DIY Chatroom Home Improvement Forum
Old 01-02-2008, 12:15 PM   #1
New drawers not shutting properly....
Bought this dresser from Restoration Hardware http://www.restorationhardware.com/r...02&navCount=36
and after a few months the drawers couldn't be pushed in. At first I thought that maybe the wood was swelling from moisture but a pro furniture fixer came out and said that the whole dresser was sagging preventing drawers from fitting through slot. It was deemed unfixable and Restoration Hardware replaced it. Now I'm afraid the same thing is happening again but just one drawer this time. Is this a carpentry or wood defect? Anyone experienced something similar? Just want more info before I call RH again. Thanks!
olehouse is offline   Reply With Quote
Old 01-05-2008, 09:23 PM   #2
remodeling pro
Sounds like it may be something with the design of the piece. One thing I know for sure, for the price of any furniture from Restoration Hardware, I'd damn well expect it to work for a long time. I would be thinking refund, and looking elsewhere. If not, be sure to establish a strong, continious paper trail of this problem for future referance.
troubleseeker is offline   Reply With Quote
Old 01-06-2008, 01:37 AM   #3
Rewards Points: 264
1360?? Wow. Just wow. No telling what the problem is, perhaps they "restored" with green wood and it warped?
moneymgmt is offline   Reply With Quote
Old 01-06-2008, 08:54 AM   #4
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,382
Are you storing anything unusally Heavy in it,..??..??
Old 01-06-2008, 09:12 AM   #5
Is your home humid? A humidifier in the room? A swamp cooler?
End Grain is offline   Reply With Quote
Old 01-06-2008, 03:27 PM   #6
(the original)
Rewards Points: 756
Humidity should have little or no effect except on unfinished drawer parts, if any. It sounds to me like it's an overpriced, poorly constructed copy. "solid maple and maple veneer".....I'd bet the only solid is face frame, top banding, and feet and the veneer is on thin particle board. Get a refund. For that price, you should be able to find a real antique.
ratherbefishin' is offline   Reply With Quote
Old 01-15-2008, 08:42 PM   #7
Cabinet GURU
Looks like an inset drawer...if the manufacturer did use dryers to dry their wood well .....the change in temperture is gonna do that. Id say major manufacturer defect ...send it back again .
michael.skofield is offline   Reply With Quote
Old 01-16-2008, 06:59 AM   #8
47_47's Avatar
Rewards Points: 58
If the dresser is sagging, either it is poorly constructed, overloaded or a combination of both. I would send it back and look elsewhere.
47_47 is offline   Reply With Quote
Laptop is shutting off ruwilde59 PC Repairs & Upgrades 6 11-16-2007 10:51 PM
Help with drawers :) hummin40 General DIY Discussions 11 10-24-2007 05:50 AM
properly nailing down 1/2" osb sheeting over lath FISH275 Roofing/Siding 2 04-08-2007 12:49 PM
is this a properly done rubber roof? ssl Roofing/Siding 20 09-20-2006 01:55 PM
5 Ton split system keeps shutting down mahjohn HVAC 1 06-10-2006 07:31 AM
