New Construction Wall Framing - Carpentry - DIY Chatroom Home Improvement Forum
Old 11-05-2011, 12:26 PM   #1
New construction Wall Framing
what nails are and ( nailer ) if any? to shoot / nail a 2x / 4x stud in Place , In commercial wall framing with 3x plate stock ? ( no specs )
dennis bowen is offline   Reply With Quote
Old 11-05-2011, 12:47 PM   #2
Framing Contractor
How come there are no spec's? Do you have permits?
Joe Carola
Joe Carola is offline   Reply With Quote
The Following User Says Thank You to Joe Carola For This Useful Post:
woodworkbykirk (11-05-2011)
Old 11-05-2011, 03:24 PM   #3
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,112
1st off commercial wall framing doesnt use plates. they use track and steel stud, heavy gauge for exterior walls and light gauge for partitions/curtain walls
woodworkbykirk is offline   Reply With Quote
The Following User Says Thank You to woodworkbykirk For This Useful Post:
Big Stud (12-01-2011)
Old 12-01-2011, 07:47 PM   #4
Crusty Old Dude
Big Stud's Avatar
You COULD frame a commercial wall with wood studs, but it all has to be non combustible. That's why metal stud framing is usually used with wood studs (non com) only on rough door and window openings for nailing finish frames and trim to.
Big Stud is offline   Reply With Quote
Old 12-02-2011, 02:30 PM   #5
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
They still use wood commercially all the time.
But anyways, I have no idea what the op is asking anyways.
titanoman is offline   Reply With Quote
Old 12-02-2011, 05:57 PM   #6
Most fast food places and light commercial are wood frame, there should be a nailing schedule for any commercial building though.
Ninjaframer is offline   Reply With Quote
Old 12-02-2011, 06:23 PM   #7
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
he's gone.......................
tcleve4911 is offline   Reply With Quote
Old 12-02-2011, 08:52 PM   #8
wood frame is extremely rare for light commercial here. do to fire codes.
if there is wood framing its because its in a very old building in most cases with no other spaces which need a fire stop
Old 12-02-2011, 09:02 PM   #9
Around here you see it with 3-4 story office buildings, gas stations, resturaunts, ect.
Old 12-02-2011, 11:01 PM   #10
Old School
Willie T's Avatar
Ninjaframer is right on target. The Wood Councel pamphlets dca-3 and dca-4, I believe, describe using wood in structural applications.
Wood of sufficient size is actually safer than many steel structures when flame resistance timeframes are considered.
Willie T
Old 12-03-2011, 12:03 AM   #11
It's true, as a firefighter I've seen wood outlast light weight steel many times.
Old 12-03-2011, 09:25 AM   #12
i personally hate steel stud, im a residential renovation carpenter. but do some commercial work.. just around here they want steel stud do to "no combustables".. rough openings still get 2x's for nailers for trim and hanging doors from though...
Old 12-03-2011, 03:00 PM   #13
Tizzer's Avatar
Rewards Points: 460
to start his commercial job.........
Tizzer is offline   Reply With Quote
Help framing rake wall lesp Carpentry 2 03-29-2011 06:17 PM
interior wall framing question ratherbefishing Building & Construction 2 03-20-2011 12:24 AM
Shower Half Wall Framing Colbymom Building & Construction 7 08-01-2008 10:49 AM
Framing wall under duct JiD Building & Construction 1 03-31-2008 12:10 PM
