Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 01-29-2011, 10:21 AM   #1
New Construction: Is This to Code?
I have a 1.5 year old, 2 story home in Iowa. There have been some pretty large cracks on certain second floor walls, and a lot of doors not latching. Today I noticed the large basement egress windows do not have a typical header, and it looks as if the plates are sagging in the center of the windows. The "header" that is above the window is basically two 2x6s, on the flat, supported by one jack stud on either side. One of the plates above this "header" has a break without any support, other than the "header", below it. I am pretty sure that, on the flat, 2x lumber is not capable of supporting a 5' span of weight bearing wall, such as my windows. There were several issues that the building inspector caught prior to passing, maybe this was overlooked? Can anybody verify this? Thanks.
usa1corey is offline   Reply With Quote
Old 01-29-2011, 01:58 PM   #2
Please post pictures.
If you need help doing so:
How To Post Photos Using PhotoBucket Or Flickr
or
How to attach a photo to a post
mjzraz is offline   Reply With Quote
Old 01-31-2011, 02:58 PM   #3
This is what's left of the photo after cutting it down to a submittable size.
New Construction: Is This to Code?-dscf1663.jpg
Old 01-31-2011, 03:09 PM   #4
Concrete & Masonry
Pull the insulation back first & check to see if the floor joists are hangered to the skirt. Or possibly the skirt is even doubled up for the actual header.
jomama45 is offline   Reply With Quote
Old 01-31-2011, 03:13 PM   #5
Here is another angle with a lower res camera.
Old 01-31-2011, 03:26 PM   #6
I pulled away the insulation and the floor joists are hangered.
Old 01-31-2011, 03:32 PM   #7
Concrete & Masonry
Is the rim/skirt board doubled up over the window?
If so, the doubled up 2x's on the flat aren't being used as a header.
The Following 2 Users Say Thank You to jomama45 For This Useful Post:
Tom Struble (01-31-2011), usa1corey (01-31-2011)
Old 01-31-2011, 03:42 PM   #8
I took a measurement on the inside, from the rim joist to the edge of the 2x6 plate. It came out to be 2-1/2" so it must be doubled. I feel a little better now, thanks jomama45.
Old 01-31-2011, 04:18 PM   #9
Residential Designer
AndyGump's Avatar
Send a message via Skype™ to AndyGump
That looks to me like some sort of home-made glu-lam??
Andy.
AndyGump is offline   Reply With Quote
Old 01-31-2011, 05:52 PM   #10
SDC
SDC's Avatar
Andy.
It looks like a good insulation job to me......caulked and sealed between all layers.
If the rim is doubled and I-joist hung, it should be no issue, as noted from jomama45
David Cookman
SDC is offline   Reply With Quote
Old 02-01-2011, 12:27 PM   #11
Moderator
Termite's Avatar
Agreed, provided the rim board used is able to serve as a header. An i-joist floor system does not use dimensional lumber rims, so an OSB rim was probably used. Many/most are not rated as headers. LVL's are typically used at these locations.
USA1Corey, can you post a picture of the rim joist that the i-joists are hangered to? If it has a veneer face, you're good. If it looks like OSB there might be an issue, depending on the brand.
Old 02-01-2011, 01:32 PM   #12
uva uvam videndo variafit
WirelessG's Avatar
BTW - You mentioned that you were having trouble posting pictures due to the size of the pics. Try downloading this tool from Microsoft. It allows you to right click and resize pictures (either resizing the original image or making a new image). There is little to no difference in the image, but the file size goes from 2 megs to 115k.
http://www.microsoft.com/windowsxp/u...schelman2.mspx
WirelessG is offline   Reply With Quote
The Following User Says Thank You to WirelessG For This Useful Post:
pyper (02-01-2011)
Old 02-01-2011, 05:04 PM   #13
Carpenter
dtsman's Avatar
How is that vinyl window or door in the picutre operating?
If the wood above it starts to sag from weight above, it will bend that vinyl frame easily. If that window is functioning properly, then issue may not be in that area.
Bo
Remember,
If the women don't find you handsome,
they should at least find you handy.
(Red Green)
dtsman is offline   Reply With Quote
Tags
building code, egress window, header, new construction
Carrier Error Code 33 russell124 HVAC 4 12-04-2010 08:19 PM
Soft Hearted Construction Guys Wildie Building & Construction 0 11-29-2010 07:05 PM
Canadian Electrical Code Question flemingetq Electrical 4 11-25-2010 10:42 AM
GFCI breakers equivalent to GFCI outlets? Any code pitfalls? TomServo Electrical 27 02-04-2010 11:59 PM
Electrical re-wire to code diy-safely Electrical 8 01-04-2010 04:19 PM
