-   -   New Construction: Is This to Code? (http://www.diychatroom.com/f14/new-construction-code-93853/)
usa1corey 01-29-2011 10:21 AM
I have a 1.5 year old, 2 story home in Iowa. There have been some pretty large cracks on certain second floor walls, and a lot of doors not latching. Today I noticed the large basement egress windows do not have a typical header, and it looks as if the plates are sagging in the center of the windows. The "header" that is above the window is basically two 2x6s, on the flat, supported by one jack stud on either side. One of the plates above this "header" has a break without any support, other than the "header", below it. I am pretty sure that, on the flat, 2x lumber is not capable of supporting a 5' span of weight bearing wall, such as my windows. There were several issues that the building inspector caught prior to passing, maybe this was overlooked? Can anybody verify this? Thanks.
mjzraz 01-29-2011 01:58 PM
Need pictures
Please post pictures.
If you need help doing so:
http://www.diychatroom.com/f98/how-p...-flickr-49655/
or
http://www.diychatroom.com/f98/how-a...to-post-20532/
usa1corey 01-31-2011 02:58 PM
Basement Window Photo
1 Attachment(s)
This is what's left of the photo after cutting it down to a submittable size.
jomama45 01-31-2011 03:09 PM
Pull the insulation back first & check to see if the floor joists are hangered to the skirt. Or possibly the skirt is even doubled up for the actual header.
usa1corey 01-31-2011 03:13 PM
Basement Window Photo 2
1 Attachment(s)
Here is another angle with a lower res camera.
usa1corey 01-31-2011 03:26 PM
Basement Window Follow-up
I pulled away the insulation and the floor joists are hangered.
jomama45 01-31-2011 03:32 PM
Is the rim/skirt board doubled up over the window?
If so, the doubled up 2x's on the flat aren't being used as a header.
usa1corey 01-31-2011 03:42 PM
Bsmt Window
I took a measurement on the inside, from the rim joist to the edge of the 2x6 plate. It came out to be 2-1/2" so it must be doubled. I feel a little better now, thanks jomama45.
AndyGump 01-31-2011 04:18 PM
That looks to me like some sort of home-made glu-lam??
Andy.
SDC 01-31-2011 05:52 PM
Andy.
It looks like a good insulation job to me......caulked and sealed between all layers.
If the rim is doubled and I-joist hung, it should be no issue, as noted from jomama45
Termite 02-01-2011 12:27 PM
Agreed, provided the rim board used is able to serve as a header. An i-joist floor system does not use dimensional lumber rims, so an OSB rim was probably used. Many/most are not rated as headers. LVL's are typically used at these locations.
USA1Corey, can you post a picture of the rim joist that the i-joists are hangered to? If it has a veneer face, you're good. If it looks like OSB there might be an issue, depending on the brand.
WirelessG 02-01-2011 01:32 PM
BTW - You mentioned that you were having trouble posting pictures due to the size of the pics. Try downloading this tool from Microsoft. It allows you to right click and resize pictures (either resizing the original image or making a new image). There is little to no difference in the image, but the file size goes from 2 megs to 115k.
http://www.microsoft.com/windowsxp/u...schelman2.mspx
dtsman 02-01-2011 05:04 PM
How is that vinyl window or door in the picutre operating?
If the wood above it starts to sag from weight above, it will bend that vinyl frame easily. If that window is functioning properly, then issue may not be in that area.
Bo
Remember,
If the women don't find you handsome,
they should at least find you handy.
(Red Green)
