Need To Taper The Thickness Of A 2x8 - How? - Carpentry - DIY Chatroom Home Improvement Forum
Old 09-08-2011, 05:07 PM   #1
Need to taper the thickness of a 2x8 - How?
I need to taper the thickness of a 2x8 that is about 14' long. I need full thickness at one end and about 1/4" less at the opposite end. Any suggestions on the best way to accomplish this? My initial thoughts were to use a band saw or table saw - I don't have either of these tools, but know people who do. Other than that, I was going to go to the lumber yard and see if they have any suggestions.
Thanks in advance for any advice
Brian
laportebj is offline   Reply With Quote
Old 09-08-2011, 05:10 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Plane.
Either a hand plane (block plane) or a power plane.
XXX
Old 09-08-2011, 05:58 PM   #3
Civil Engineer
Rewards Points: 4,782
I would use a router. Set up a fence at the appropriate angle, use a straight bit of appropriate depth, make several passes, you are good to go. A piece that long cannot be worked effectively using a taper jig in a tablesaw.
Daniel Holzman is online now   Reply With Quote
Old 09-08-2011, 06:22 PM   #4
kwikfishron's Avatar
Rewards Points: 596
My question is why would you need to do that?
I’ve never in construction ever came across a situation were doing something like that would be the best solution.
Not quite fallowing you on the router thing Daniel.
kwikfishron is online now   Reply With Quote
Old 09-08-2011, 06:27 PM   #5
DIY staff
Rewards Points: 7,174
1/4" in 14 feet----Could you tell us what you are trying to do?
Old 09-08-2011, 07:32 PM   #6
Experienced
Jackofall1's Avatar
So you want to trim a 14' 2x8 by a 1/4", from 1-1/2" to 1-1/4" or .017" per foot of board?
I don't know of any saw that would be capable of doing that task there is more deviation on a 2x8 than you are proposing to remove.
Mark
The Following User Says Thank You to Jackofall1 For This Useful Post:
oh'mike (09-08-2011)
Old 09-08-2011, 07:38 PM   #7
Framing Contractor
Rewards Points: 120
Just go to the lumberyard and search through the pile. We often find some that have one end planed down. Never had an opportunity where it was beneficial though.
sixeightten is offline   Reply With Quote
Old 09-09-2011, 06:59 AM   #8
Rewards Points: 5,336
This is an odd request and not something a DIYer does or can do expeditiously.
If you tell us the reason, we might be able to suggest an alternative solution more readily done.
Ron
B. Franklin 1759
Need help in finding 3" recessed light housing for 1 1/8" inch ceiling thickness mystiky Electrical 5 07-09-2011 10:42 AM
Installing shower pan. How do I measure a mortar layer thickness? sukhenkoi Remodeling 1 04-13-2011 04:06 PM
Standard thickness of roof sheathing in Phoenix bethmac1221 Roofing/Siding 10 02-07-2011 07:24 PM
Plywood thickness: asked for 1/2" plywood; hardware delivered 7/16 (.437) thickness) lazzlazz Flooring 7 03-31-2010 11:25 AM
Dry wall thickness question tripower Building & Construction 14 09-02-2008 12:50 PM
