Need Suggestions - Carpentry - DIY Chatroom Home Improvement Forum
Old 01-24-2015, 01:52 PM   #1
Rewards Points: 127
Need Suggestions
I made this about 18 months ago. Took the time to apply sealer all around but alas, it has succumbed to the weather.
Looking for suggestions to re-create something similar. I like the black grain wood look. Considered doing this with the foam trim. Problem is, I live in South Florida and I think the summer heat may get to the trim.
The brass Om sign has screws brazed to the back.
CosmicMiami is offline   Reply With Quote
Old 01-24-2015, 03:48 PM   #2
Rewards Points: 1,891
Need Suggestions
Once you make it, you could glass it or simply add a marine spar.?
ron45 is offline   Reply With Quote
Old 01-24-2015, 07:10 PM   #3
Rewards Points: 127
Need Suggestions
Ah, brilliant. And to think I worked on boats many years ago. Should have thought of that myself. Thanks. What I'm thinking now is to coat all surfaces after cutting. Assembling, then coating again. BTW, the miter cuts were perfect when it was originally assembled.
Old 01-24-2015, 10:34 PM   #4
Rewards Points: 3,136
Need Suggestions
And then what do you do when all that sealer starts to peel?
Back up and take another picture so we can see the whole thing.
I'm picturing a sheet of James Hardee with the stucco pattern, and PVC trim painted with latex paint.
Old 01-25-2015, 05:17 AM   #5
Rewards Points: 664
Need Suggestions
Mount it on black glass and make the frame out of cedar.
We have stained glass windows hanging outside for
years and years with cedar frames.
You can get a piece of black stained glass at a stained glass
store.
Two Knots is offline   Reply With Quote
Old 01-26-2015, 12:22 AM   #6
Need Suggestions
Then you know, plywood is the base and teak is the trim..?
Old 01-26-2015, 05:27 AM   #7
Rewards Points: 664
Need Suggestions
yes I do, I assume this is outside? The glass and the cedar will
be able to withstand the weather.
I'm surprised though, that the teak didn't stand up to the
elements?
What do I do with this countertop - suggestions??? cweese Kitchen & Bath Remodeling 11 05-09-2011 06:39 PM
Suggestions for a Studio Apt. PNYCB Interior Decorating 10 01-24-2010 03:59 AM
Fireplace Upgrade Need Suggestions joesmithf1 General DIY Discussions 7 01-18-2010 07:25 PM
Color suggestions? kevinc Interior Decorating 2 01-04-2010 04:41 PM
Looking for suggestions on how to get some greenery in my workspace Cakebread Interior Decorating 4 10-20-2009 07:04 PM
