Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 07-30-2010, 10:02 PM   #1
Question
Need some help with a window stool/trim problem.
Hello, I trimmed out my window, but made a mistake. Now I don't want to redo the stool so is there another solution (maybe a wood filler I can push into the void)?
Thanks!
RickDel is offline   Reply With Quote
Old 07-30-2010, 10:54 PM   #2
bummer dude.
i would either remove the casing or the stool and glue in a little piece to fill that hole. match up the color and grain carefully and no one will ever know. brad nail it in from behind.
wombosi is offline   Reply With Quote
Old 07-30-2010, 11:37 PM   #3
Remodeling Contractor
How about removing the stool and cutting some more off of the back? It won't project from the wall quite as much, but would look much cleaner than stuffing a bunch of wood filler in there.
eisert is offline   Reply With Quote
Old 07-30-2010, 11:39 PM   #4
Moderator
If you remove the stool, just rip it narrower at the window and other casing set-back.
(Great minds.....)
Be safe, Gary
Clothes taking longer to dry?
Gary in WA is online now   Reply With Quote
Defog window recap greenmax General Discussion 4 05-07-2010 06:00 PM
Old Bay Window, lack of support... ogrenjr Building & Construction 6 03-04-2010 10:30 PM
Single Hung Window Removal for Drywall bparise Drywall & Plaster 2 12-12-2009 08:44 AM
Bathroom window issues? Mantaray14 Remodeling 11 12-04-2009 08:40 PM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 06:11 PM
