Need Some Help With Fireplace Base And Surround - Carpentry - DIY Chatroom Home Improvement Forum
Old 03-14-2010, 02:08 PM   #1
Rewards Points: 77
Need some help with Fireplace base and surround
Need some help guys, We are having new carpet layed down next week and need to come up with a fix for the Fireplace before then. As you can see in the pics it is a blue marble that need's to go. The base seems to be attached to some cement board were it meets with the carpet. What would be a good way to get that out? And what would be a good idea to lay back down there before they lay the crapet? I can not go any higher as the fireplace controls are all ready hard to get at with the current height of the base. How can I remove the surround marble pieces also and what would be good to replace them with? Sorry for all the question but I am new with this. My wife also hates the gold on the current fireplace is there anyway I can remove or replace with something more appealing? Thank you guys for all your help I do appreciate it.
Need some help with Fireplace base and surround-fireplace-pics-008.jpg   Need some help with Fireplace base and surround-fireplace-pics-009.jpg
bowanna03 is offline   Reply With Quote
Old 03-14-2010, 03:01 PM   #2
DIY staff
Rewards Points: 7,174
You have a steel fire box there----The slabs on the face are probably glued with mastic,firmset or liquid nails.
A couple of thin scrapers--putty knives or painters tools wedged between the steel face and the stone should pop them loose.
The base stone--same thing--along with some wood shims--should be able to get it out in one piece if you are careful and use plenty of shims.--Mike--
Old 03-14-2010, 03:15 PM   #3
Rewards Points: 77
Thanks man, I will get to it tonight. If it was your house what would you put back down as the slab on the floor? Do you think travertine or tile would work? I was thinking about putting stone veneer on the surround.
Old 03-14-2010, 05:36 PM   #4
DIY staff
What goes in is so much a mater of personal taste--I think you will need to see what's available.
You may wish to add your new durrock and maybe a wood "picture frame" before the carpet guys show up.
You can't leave the space open and hope they install the carpet square. You have to give them something to carpet against--Even if it is temporary.--Mike--
Old 03-14-2010, 05:37 PM   #5
Registered User
Termite's Avatar
Travertine will work I'm sure. Just be aware that natural stone is more delicate under-foot if it isn't set properly. If the floor is bouncy or the base is weak or flexes in any way, travertine will crack when stepped on. My suggestion is to remove the tile and backerboard, then replace the backerboard with a new piece. Your backerboard should be laid in a notched bed of thinset, then screwed down while the thinset's wet. Use thinset to lay your tile and be sure to get coverage on the entire tile.
Pry bars, chisels and a putty knife should do a fairly good job of getting the old stuff out.
Drop in corner tub with no base and little support monetzpond Plumbing 2 04-06-2009 09:28 AM
Fireplace framing/tile issue robdville Building & Construction 13 11-14-2008 08:14 AM
Oil base or latex for bathroom? Termite Painting 2 05-29-2008 11:11 PM
