Need To Replace Window Sill - Carpentry - DIY Chatroom Home Improvement Forum
Old 01-15-2011, 08:10 PM   #1
Need to replace window sill
Hello. I need to replace a window sill that has been chewed up by my pup. What kind of material should be used and will i need to do anything other than remove existing, nail in new one and caulk?
kcreds23 is offline   Reply With Quote
Old 01-16-2011, 06:55 AM   #2
Without pics, I would say use the same material. But usually pine or oak if stained, maybe poplar or pine for painted. You will probably have to remove trim under the sill as well. Pry carefully so as not to damage walls or trim.
The Following User Says Thank You to Just Bill For This Useful Post:
kcreds23 (01-16-2011)
Old 01-16-2011, 07:50 AM   #3
A door a day is all I ask
TheDoorGuy's Avatar
Is this an interior flat window stool with apron under it?
If so, take off apron to see how it is attached. You should be
able to pry up with a flat bar. Cut caulk around edges with a razor knife
to help prevent wall damage and make it easier to pry up.
Your local lumber yard should stock or be able to order matching material for you.
As Bill said, a picture would help.
Richard The Door Guy
www.thedoorguy.com
TheDoorGuy is offline   Reply With Quote
The Following User Says Thank You to TheDoorGuy For This Useful Post:
Cost to replace window with french doors kimbur96 Building & Construction 35 09-02-2011 12:48 PM
Rotted window frame bottom: Do I need to replace the whole window? Ginette Building & Construction 4 09-15-2010 08:52 AM
Replace Window with French Door--can I do this? tmonte Remodeling 1 08-27-2010 12:29 PM
sill angle problem replacement window drewhart Building & Construction 1 10-30-2008 09:56 PM
Do I need to replace a rotten sill plate met Carpentry 8 07-11-2008 09:14 AM
