-   -   Need to replace window sill (http://www.diychatroom.com/f14/need-replace-window-sill-92429/)
kcreds23 01-15-2011 08:10 PM
Hello. I need to replace a window sill that has been chewed up by my pup. What kind of material should be used and will i need to do anything other than remove existing, nail in new one and caulk?
Just Bill 01-16-2011 06:55 AM
Without pics, I would say use the same material. But usually pine or oak if stained, maybe poplar or pine for painted. You will probably have to remove trim under the sill as well. Pry carefully so as not to damage walls or trim.
TheDoorGuy 01-16-2011 07:50 AM
Is this an interior flat window stool with apron under it?
If so, take off apron to see how it is attached. You should be
able to pry up with a flat bar. Cut caulk around edges with a razor knife
to help prevent wall damage and make it easier to pry up.
Your local lumber yard should stock or be able to order matching material for you.
As Bill said, a picture would help.
