Need To Repair The Peak Of My Roof - Carpentry - DIY Chatroom Home Improvement Forum
Old 12-14-2011, 04:42 PM   #1
Need to repair the peak of my roof
When our home was built six years ago our builder placed a 6" strip of board on both sides of the peak. Those boards are breaking and haning into the attic. I need to get them fixed. I was told by a contractor that they can be fixed from the inside, I questioned this. The builder has since moved or gone out of business, At least I can't find him. ANY IDEAS.
Areser is offline   Reply With Quote
Old 12-14-2011, 04:48 PM   #2
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
Put some blocks in between the rafters where needed.
Sent from a Samsung Galaxy S2
titanoman is offline   Reply With Quote
Old 12-14-2011, 08:54 PM   #3
Rewards Points: 5,336
There are roofing shingles on the peak, not boards.
Post some photos.
Ron
B. Franklin 1759
Old 12-14-2011, 08:58 PM   #4
Disabled wood vet
titanoman's Avatar
Just as I thought. I don't have a clue what the op is talking about.
Old 12-15-2011, 01:03 PM   #5
retired union carpenter
Send a message via Yahoo to coupe
this sounds to me, like the builder used 6"boards for what we call collar ties. is the roof line sagging? is this a gabled roof? if so, you propably have verticle cracks in drywall? corner beads popping, corner tape tearing loose.
how about the joits at ridge? are there gaps at the bottom of ridge rafter joints? if so? the outside walls are spreading also, causing these verticle cracks.
this is rather an easy fix, using a cheap laser pointer, places level at one end of the roof ridge. set it level at say 1 1/2" below ridge under rafters. the laser line should be 1 1/2" under ridge at other end a well as under every rafter.
if there is a solid bearing wall under center or very close? use some solid blocking and jack roof up to 1 1/2" above laser line. and install new collar ties 2x6 level across, about 16"-24" below ridge, drilled and lag bolted to each rafter.
this should straighten the roof line, even pull walls back where they should be.
you'll still have any cracks to redo, but should stop it all from getting worse
as always, just my thoughts
good luck....coupe/Larry
take what helps? ignore the rest.
coupe is offline   Reply With Quote
Old 12-15-2011, 01:54 PM   #6
Disabled wood vet
titanoman's Avatar
If there's no more than 1 or 2 broken (and I've never seen broken collar ties. That makes no sense), the walls haven't moved anywhere. Just scab some soldiers alongside the broken ones with several nails.
And don't be storing or hanging anything on or from them.
Old 12-15-2011, 04:11 PM   #7
I've seen collar ties broken several times, when using 1x6 as ties. just from weight of roofing shingles. much less than the snow load the northeast experienced last winter!
I was simply trying to help the op, with method to fix if that indeed is the case?
Old 12-15-2011, 04:50 PM   #8
Disabled wood vet
titanoman's Avatar
I guess that's why I've always used 2x for collars.
Old 12-15-2011, 05:16 PM   #9
that is exactly why I suggested using 2x6
Old 12-16-2011, 01:01 PM   #10
Maybe if the OP comes back with more details, some of these suggestions might prove relevant, but I've never understood suggestion after suggestion when the post was unclear as to what the issue actually was.
Maybe a Theoretical Problem forum where they only post their hat size and everybody guesses what the home improvement issue is.
It could be subtitled, "Beating the dead horse" forum.
Returning to the original program...
Maybe it's termites. Yeah, that's the ticket!
Ron
B. Franklin 1759
Old 12-16-2011, 01:18 PM   #11
Disabled wood vet
titanoman's Avatar
You got a problem with a couple of carpenters talking about collar ties amongst themselves?
If the op comes back, fine. If not, that's fine too.
Old 12-16-2011, 02:06 PM   #12
What you're doing is addressing, in a scatter gun approach, all things roof related, or structurally related to roof framing.
Does it address the OP problem? Who knows? All we know is that something that's 6" is of issue and roof related.
Does a buried discussion about collar ties benefit anyone?
Makes more sense to me, to start a new thread called, Collar ties, the rights and wrongs of roof structure. It's on point and people can find it.
Not that I've not been quilty of mixing chaff with wheat on an occasion or two...
This is probably one of them.
Ron
B. Franklin 1759
Old 12-16-2011, 02:12 PM   #13
Disabled wood vet
titanoman's Avatar
Maybe people like you could benefit from discussions like the one we were having before you so rudely jumped in on. Your posts right now are useless to anybody. Why are you even here right now?
Now if you want to talk shop...
Old 12-16-2011, 02:15 PM   #14
The thread is all yours.
Ron
B. Franklin 1759
Old 12-16-2011, 05:15 PM   #15
Maybe.
Ron, this is a carpentry DIY forum. exactly how much information do you need?
typically, anything attached near the ridge of a roof is called "collar ties" these do not usually break and hang into an attic without cause!
the thread was running smoothly until you chimed in with not understanding suggestions? maybe you're better suited for a forum of polyester v/s cotton ties? like a fashion or wardrobe type of forum.
something has caused these collar ties to crack and fall! weather it was snow load in his/her area or incorrect framing of the structure? we don't know!
maybe the op took the suggestions, fixed it and moved on? others may have learned something, simply by reading? that was the intention of us who posted on this thread.
if it is unhelpful to you? skip over it! it has been an informational thread if nothing else? that being said, I hereby change my suggestion of 2x6's to 6" strip of 6 ply 3/4" plywood. anything that has a near straight grain line, is susceptible to cracking. 6 ply 3/4" plywood will be just as strong and not going to crack in any direction.
somehow, this informative thread, has now turned into an argumentative one.
since the thread now belongs to Tritonman?
I'm guessing Ron will no longer be reading or learning? just in case he needs it in the future
Flat roof repair Bholt222 Roofing/Siding 2 07-22-2011 11:34 AM
Hail damage roof and siding repair advice needed Ed G Building & Construction 3 06-24-2011 12:08 PM
Extend House Roof Over Back Deck Justahome Carpentry 17 04-05-2009 03:42 PM
Who is liable for the roof repair? shanemcguire1 Roofing/Siding 2 04-05-2009 07:49 AM
Need roof repair in Phoenix AZ pawned Roofing/Siding 7 06-12-2006 06:46 PM
