Need To Remove Base Molding - Carpentry - DIY Chatroom Home Improvement Forum
Old 02-16-2014, 04:07 PM   #1
Rewards Points: 874
Need to remove base molding
Put a piece on that is not straight. What is the best way to remove it? Pry it off? Thanks.
Mstrlucky74 is offline   Reply With Quote
Old 02-16-2014, 04:15 PM   #2
bbo
yep. flat pry bar, they make small ones for trim removal.
also when pulling the finishing nails/brads/whatever, pull them out through the back side. this avoids damage on the front.
bbo is offline   Reply With Quote
Old 02-16-2014, 04:21 PM   #3
Rewards Points: 12,794
Tap in 4" wide putty knife where the nail is from the top ad pull back slightly to form a gap. Then tap in a flat bar or trim bar between the knife and the trim using the putty knife to protect the wall.
Should only be attaching the trim where the studs area.
A simple fast way to lay it out is by finding 2 studs to see how there spaced then laying a tape measure in the locked position on the floor with the tip in the middle of the first stud.
Old house? Then it's near impossible to set it level along the whole length.
Set a piece of thin plywood on the floor to set the moulding on at the two ends and use 1/4 round to cover up the gaps.
Old 02-16-2014, 04:24 PM   #4
Rewards Points: 3,396
You can start the pry with a puddly or spackle knife first.
Problems. Can drill head off if nail.
Electrical dykes ( diagonals ) helpful also
ritelec is offline   Reply With Quote
Old 02-16-2014, 05:27 PM   #5
DIY staff
Rewards Points: 7,174
I like to use a painters tool--tap it in between the trim and wall--and gently pry the trim out a bit---then find the nail with the painters tool--set the tool on top of the nail---hit it with a hammer.
The nail will be bent and pulled out of the back of the trim.
BigJim (02-17-2014)
Old 02-16-2014, 07:20 PM   #6
Rewards Points: 874
Thanks guys...came off fine with the painters tool.
The Following User Says Thank You to Mstrlucky74 For This Useful Post:
oh'mike (02-16-2014)
Old 02-17-2014, 08:33 AM   #7
Interesting..............
Old 02-17-2014, 01:16 PM   #8
bbo
Its all in the wrist.
Old 02-19-2014, 01:56 AM   #9
Rewards Points: 141
I had to remove some molding and use this , was easy to use slid right behind the base board real easy.
http://www.homedepot.com/p/Hyde-9-1-...-100123416-_-N
bote110 is offline   Reply With Quote
How to tile around a Pre fab shower base geoffthemonk Building & Construction 1 11-07-2009 10:10 AM
1000sq ft of teak, do i remove base trim, saw door casing ?? PendletonCowboy Flooring 4 10-20-2009 05:04 AM
base molding painting w/ carpet fabian Painting 2 04-02-2009 08:57 PM
How do you remove plaster cove molding? mattedfred Remodeling 3 10-28-2008 04:48 PM
Base molding or carpet first??? Dan N Flooring 5 02-01-2007 09:29 AM
