Need To Redo Back Fence - Carpentry - DIY Chatroom Home Improvement Forum
Old 04-25-2013, 12:03 PM   #1
Novice
Question
Need to redo back fence
I'm dealing with wood, so I guess this belongs here.
So, I live in a townhouse in a suburban housing development. As such, the backyard fence is crap. My family can't really afford to replace the entire thing, so as the family DIY-er, it's up to me to fix it.
The main problem is that some of the boards have warped, curving upwards and dislodging the boards that are supposed to keep them from doing exactly that. There's also a lot of mold that needs to get scrubbed off. The lock on the back gate is also in need of replacing-- it's rusty and practically falling off. And then the entire thing needs to be re-stained-- the stain the builders used is practically gone now, and the fence is gray where the sun hits it (which is practically everywhere).
So, I guess my question is what would be the best lumber to get to replace the boards that need replacing? This is probably going to be the last time we do this, so I want to get something that won't warp, won't grow mold, and will keep its color after staining, and that's relatively affordable. The stain has to be weather-proof as well, so I need something that doesn't need to be re-applied every summer.
Any ideas?
WannaDoAReno is offline   Reply With Quote
Old 04-25-2013, 06:56 PM   #2
Wood that doesn't warp, grow mold and keeps it's color after staining and isn't expensive? Hmmm.... Not sure that exists. Maybe this needs to be looked at a different way:
1. Mold issue: I assume you mean wood that doesn't rot, weathers well and won't be a mold issue in a wet area. Mold I can't help you with, the other 2 are easy. Go with Pressure Treated Exterior Lumber. It's made for decks, fences, posts, sheds and pretty much anything else you have for outside use but it's not cheap. That's not to say it's super expensive but your going to get what you pay for and pressure treated is going to give you the most bang for your buck.
2. Warp: All wood can and will warp under certain conditions, the type of wood it is means it's more susceptible (like the sap wood of a gum tree) or less susceptible to warping. Best suggestion any of us can give you is to screw the boards together using deck screws, not drywall screws (as drywall screws will rust/corrode) and to secure them well.
3. Stain you don't have to redo every year. Okay, how about every 3 years? There are stains out there that you can use that will give you a good finish for a few years but none are going to give you a great finish permanently.
If you never want to touch this fence again perhaps you need to look at some of the vinyl fences on the market. More money up front but in the end it'll cost less than if you have to keep redoing the fence, depending on how long you live there. I'll let someone else recommend the best stains from their experience.
TheJerk is offline   Reply With Quote
Old 04-26-2013, 12:34 AM   #3
Dave Sal's Avatar
Rewards Points: 576
Any ideas?
Can you post a few pics so we can see what you're talking about?
Dave Sal is online now   Reply With Quote
How to add a dividing fence to chain link fence and house with siding catburke Building & Construction 1 10-10-2013 01:33 AM
T-intersection - fence gets hit constantly Chinagirl Building & Construction 86 09-14-2013 12:38 PM
Didn't have the 'green thing' back in our day gma2rjc Green Home Improvement 6 07-05-2012 06:23 AM
Advice needed on staining wood fence deerhunter Painting 0 10-29-2010 11:27 PM
Severe Drainage Issue kirridam Landscaping & Lawn Care 11 07-25-2009 07:44 AM
