Need Recommendations For Window Replacement Inside Old Door - Carpentry - DIY Chatroom Home Improvement Forum
Old 04-30-2010, 03:31 PM   #1
need recommendations for window replacement inside old door
I have an old door at the ground level which has a this window insert consisting of a bunch of glass panels that can be all turned with a handle (see photo where the panels are closed). Needless to say, it does not provide good insulation. Rather than replacing the whole door which is overall in a pretty decent shape, I want to replace this old window insert with a regular window that is well insulated. Can you recommend what sort of window I should pick? I am not sure what the exact size of the opening is but the insert measures about 21" wide by 33" high. I want it to be clear. Thank you!
ilyaz is offline   Reply With Quote
Old 04-30-2010, 04:07 PM   #2
waterman1971's Avatar
Rewards Points: 150
I would go with some sort of plexiglass or lexan. Tempered glass is required in doors for good reason.
waterman1971 is offline   Reply With Quote
Old 04-30-2010, 05:33 PM   #3
kwikfishron's Avatar
Rewards Points: 90
Is there a trim you can remove and then remove the window unit and something new can be inserted and then the factory trim re-installed?
If so, how thick does the new unit need to be so the factory trim will fit and hold properly?
Is this a metal or wood door?
kwikfishron is offline   Reply With Quote
Old 04-30-2010, 07:05 PM   #4
The door is wood 1 5/8" thick. I am not sure whether it has a trim or not. Maybe this poorly lit closeup picture will help...
need recommendations for window replacement inside old door-door_win_closeup.jpg
Old 04-30-2010, 07:16 PM   #5
Rewards Points: 5,336
Contact a local glazier, they will be able to replace this inefficient jalosie unit with an insulated low e replacement.
Ron
Replacement Sliding Door Sizes Anthony M Building & Construction 1 01-05-2010 07:11 PM
Right Size Door for replacement? SJCJohn Remodeling 6 12-09-2009 08:43 AM
exterior door replacement analogmusicman Carpentry 7 02-11-2009 03:57 PM
Entry Door---My Story----Advice Please rossmoor Building & Construction 3 02-29-2008 10:13 PM
french patio door replacement nasa-hvac Building & Construction 2 06-15-2005 09:49 AM
