Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 01-28-2013, 11:41 PM   #1
Need to raise saw 1/32"
I built a miter saw stand with extension wings, which due to my error are about 1/32" above the level of the metal saw table. What's the easiest/cheapest way to raise the entire saw 1/32" so it's level -- preferably something I can get at Home Depot or Lowers? I found some 1/32" plywood online, but don't feel like spending $20 for it + shipping. Thanks.
horsemedic is offline   Reply With Quote
Old 01-28-2013, 11:49 PM   #2
Got a picture?
Old 01-28-2013, 11:56 PM   #3
http://www.thisiscarpentry.com/wp-co...5604231363.jpg
It's essentially this. My saw table sits 1/32 lower than that 12" wide top in the diagram. I need to get it flush without recutting all my spacers.
Old 01-29-2013, 12:10 AM   #4
How thick is fermika (spelling). Counter top material. Smoth too.
grizzzlle is offline   Reply With Quote
Old 01-29-2013, 12:21 AM   #5
Formica.
Might want to check out the Harware store for fender washers.
http://www.bokers.com/fender_washers.asp
Old 01-29-2013, 07:28 PM   #6
journeyman carpenter
woodworkbykirk's Avatar
believe it or not playing cards, i use them for micro shims all the time. the thickness of the card is roughly 1 / 32" if i need it to be thicker i fold it.. then double it etc.. the plastic from pop bottles works well for exterior micro shims
woodworkbykirk is offline   Reply With Quote
The Following User Says Thank You to woodworkbykirk For This Useful Post:
oh'mike (01-30-2013)
Old 01-30-2013, 06:44 AM   #7
When I built mine I set the saw height a little low so I could shim to perfection with cereal box tops.
Fairview is offline   Reply With Quote
Old 01-30-2013, 07:00 AM   #8
Super Moderator
Steel shim stock is nice----aluminum from cans works---washers--wood ripped on the table saw---
Old 01-30-2013, 08:17 PM   #9
Mountain's Avatar
I commonly cut pop cans into sheets and use them for shims. folded over in two or possibly three get you about 1/32 inch. Get em the right hieght and staple them down where the saw feet will set on them. Another I have used is old tin can lids.
Another option might be to check the foot pads on the bottom of the saw and adjust using them, if not adjustable you may be able to thread screws/bolts into them and make them adjustable. Just pick a small taper headed one drill a small hole and tap it. For 1/32" you would want to counter sink the hole so that the screw/ bolt could be run flush to the bottom.
I can't count the number times I have done exactly the same thing, as a result I have had a fair bit of experience with this...lol
Mountain is offline   Reply With Quote
The Following User Says Thank You to Mountain For This Useful Post:
Old 01-30-2013, 08:29 PM   #10
yah the only thing with aluminum that thin is that its really sharp
sunken sidewalk to raise D270 Concrete, Stone & Masonry 5 07-03-2012 02:13 PM
raise sunken living room with fireplace jamxi Flooring 12 06-05-2011 05:33 PM
Raise ceiling/Tray Ceiling. Is it even possible? Bombcru Building & Construction 10 02-08-2011 02:01 AM
Raise a flower bed already planted ? dkgetz Landscaping & Lawn Care 3 03-17-2010 07:18 PM
Raise header of house wall plus add more header capslock Building & Construction 22 02-01-2010 10:13 PM
