Need Pergola Plans - Carpentry - DIY Chatroom Home Improvement Forum
Old 12-25-2008, 07:25 PM   #1
Need Pergola Plans
Can Anyone Give Me Guidance About Getting Plans For A Freestanding Pergola On A Cement Patio. Reaaly Appreciate The Help, Longing For Spring!
rlane is offline   Reply With Quote
Old 12-25-2008, 09:49 PM   #2
Rewards Points: 1,016
Many different ways to build one - I built ours which encompnasses about 1000 sq ft with various areas (what we call the main, dining, walkway, and bedroom patios). When I built I drove neighborhoods looking at how others built, web searches, etc. We did what I call "hanging posts" which put the cross support members up high maximizing the height and view. Here's a link to some pictures of it: http://www.webjeepers.com/homestead.html
  • 4x4 posts
  • 2x6 joists
  • 2x2 toppers (~30" span across the joists)
  • all above doug fir, rough saw finished by the lumber yard
  • corbels cut by the lumber yard
  • 2x6 ledger board on the house
  • 2 primer and 1 finish coats before assembly, another finish coat sprayed once in place (all the 2x2 was the most work)
  • joists/posts lag bolted together (a electric impact wrench is a big plus)
  • 2x2 toppers screwed down, not nailed
  • posts in a bracket bolted into the concrete patio, bracket creates a space so the wood is not left in the wet
Old 03-26-2009, 02:15 AM   #3
found a manual of a free standing LINK REMOVED
and some pictures you can refer to... might help
Last edited by Termite; 03-27-2009 at 11:02 AM. Reason: Site rules violation: Advertising link removed
samcurt012 is offline   Reply With Quote
Basement BAR Plans Boomer313 Remodeling 9 04-14-2013 12:00 AM
Pergola - paint or stain - then maintenance woodsglen Painting 2 07-15-2008 08:30 PM
ledger attached to brick for pergola soupdizzle Carpentry 7 07-07-2008 03:43 PM
Starting an outbuilding - plans, permits? Park Building & Construction 3 02-14-2006 02:01 PM
pergola Q's? phenom Building & Construction 2 05-17-2005 06:21 PM
