Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 07-06-2009, 10:11 AM   #1
Default Need Mitered Rip Cut- Have No Table Saw
I need a beveled edge on a single 32" long 2 x 4 for installing an air conditioner in a vinyl window... and I don't own a table saw.
My local Home Depot won't do rip cuts nor will my local mom and pop lumber place.
I'm pretty sure Home Depot doesn't rent table saws, but, even if they did, I can't really justify spending that kind of money for a single cut.
It's, as far as I can tell, the most ideal scenario for installing the AC (I need about a 6 degree slant on the wood so the water drains properly, and, no, I'm not going with shims) so I'm willing to shell out some money for the cut, just not tool rental money.
Any ideas?
scott123 is offline   Reply With Quote
Old 07-06-2009, 10:50 AM   #2
Experienced goon
Surprised the local shop won't do it... I haven't found one in the NYC area (haven't looked), but when I lived in upstate NY, the local place cut and charged by the foot. No friends with table saws? What about a local handyman?
jpelzer is offline   Reply With Quote
Old 07-06-2009, 11:18 AM   #3
What tools do you own? A belt sander would work. A plane and some hand sanding. A circular saw set on 6º. These come to mind as alternatives to a table saw.
CVGFir is offline   Reply With Quote
Old 07-07-2009, 01:01 AM   #4
239 Adventurer
jbaker1516's Avatar
Have you tried a local lumber yard? ... not a HD or Lowe's
jbaker1516 is offline   Reply With Quote
Old 07-07-2009, 10:45 AM   #5
HD's rent table saw. The one by me rents the nice Dewalt contractor saw for 35/day or a little less for 4 hours. Try finding a wood working shop. they may be willing to do it for a little cash.
You could also do it with a cirular saw. You could mount your 32" board to a piece of plywood with 1-2 2x4's next to it to give you a wider base. Then clamp another board on top of it to act as a cut guide.
beerdog is offline   Reply With Quote
Old 07-07-2009, 10:56 AM   #6
011000100110111101101111
DangerMouse's Avatar
he just doesn't want to pay for a one time use...can't blame him!
but hey, it's PINE fer cryin' out loud....
seems to me, it's easiest to just go 'old school'..... grab a good, sharp knife, go sit on yer front porch and do a Jed Clampett on it to shape the bevel, then used the side you whittled as the bottom and no-one will be the wiser.
DM
Magical, Musical, Mysterious FUN!
http://www.youtube.com/user/MickeySoume
Now Featuring: Mickey's Multi-Talented Mutts!
Old 07-09-2009, 05:26 PM   #7
gravity always wins
You only need 6 degrees. DM's idea will work or get the cheapest block plane you can find. You could probably sand 6 degrees off rubbing it on your sidewalk.
More On This Topic
The rise in mega-home improvement stores has turned the ordinary homeowner into a home improvement expert. The instructions on how to perform household repairs are readily available online. All you need are the proper tools and supplies. Here's how to... Read More »
You can see that looks really nice. It looks quite artistic. And I have to remind you to, you know, that we just, we had this little photo copies from that book, okay? We enlarge and with this we had, you know, a very good shape to follow. Then we did... Read More »
Alright, I hope you enjoyed the game of beer pong. Now I'm going to teach you exactly how to build your own table at home. Alright? It's very easy. I actually went to Home Depot and got some supplies. I got a plastic table just like this running about... Read More »
In this step we will remove the rip vents, install the mider gage, and cut the sidewall boards at a sixty degree angle. To remove the rip vents all I need to do is pull it up off the table saw. To install the mider gage put it in the slot of the table... Read More »
So, let's see if we can find some material that would make that shim. It looks as though, on this particular instrument that this unit here, is exactly for that purpose. But it is level so we can put a shim under here and we only need, maybe, a one... Read More »
Super glaze bar table finish jlwiu1 General Discussion 4 07-16-2009 09:46 AM
Help please with table support Stonefury Carpentry 2 01-07-2009 03:05 AM
Looking for Japanese dining room table plans dantefontana Carpentry 3 03-01-2008 10:11 PM
Need Advice for Adding Wheels to Table HandyDottie Carpentry 7 01-27-2008 09:44 PM
Question about table saws,... tribaloverkill Tools 28 04-13-2007 10:47 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
