Need Idea For A Simple Lift To 2nd Floor Porch. - Carpentry - DIY Chatroom Home Improvement Forum
Old 10-30-2011, 07:19 AM   #1
need idea for a simple lift to 2nd floor porch.
I'm not really a handyman but I need a simple, workable idea for a way to lift groceries, etc. from the ground level to a 2nd floor porch (the house is in a flood zone so the front door opens from the porch. There is no ground level entry. The person is getting older and has a difficult time with the stairs now, especially in bad weather and where one trip up the stairs would be doable, several trips would not. Would a hoist work or is there a better idea? and how strong would the porch roof have to be? Several bags of groceries would be what it's needed for. Thank you for any help you can give and for your time and trouble.
bratty is offline   Reply With Quote
Old 10-30-2011, 07:49 AM   #2
DIY staff
Rewards Points: 7,174
Sounds like you want an outdoor 'dumb waiter'
Power operated or rope and pulley?
Old 10-30-2011, 08:41 AM   #3
Ole Wood Worker
BigJim's Avatar
Rewards Points: 118
Harbor Freight has electric winches fairly cheap that could be used as a lift mechanism. It just depends on you how far you wish to go to make the lift. Will a swing arm over the rail work for you or will you want a hole cut in the floor to make a lift that way? Will there be two people to operate the lift or just one? (One loads on ground other takes off on porch)
New members: Please consider adding your location to your profile.
He is no fool who gives what he cannot keep, to gain what he cannot lose.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 10-30-2011, 11:47 AM   #4
Rewards Points: 5,336
Or you can use a basket with a counter weight.
Ron
B. Franklin 1759
Tags
adaptable living , hoist , lifting system
Wiring a receptacle for a lift station hydrogeo99 Electrical 4 08-18-2010 02:04 AM
Plasma TV Lift Cabinet - Lift Won't Rise - Troubleshooting Hils61 Home Theater 4 05-21-2010 09:11 PM
10x10 patio, need help w/ some simple design idea dinosaur1 Landscaping & Lawn Care 3 12-04-2009 12:13 AM
simple closet lighting theboss Electrical 8 02-16-2009 09:56 PM
Scissor Lift - How Much Weight??? JackOfAllTrades Building & Construction 9 09-08-2008 06:57 AM
