Need Help...With A Wall - Carpentry - DIY Chatroom Home Improvement Forum
Old 04-16-2011, 09:50 PM   #1
Need Help...With a Wall
I am wondering if you folks think this wall has any chance of being load bearing/structural in any way. I don't think it does but I am looking for opinions.
This is a small closet that we'd like to remove to open our cramped kitchen. The first door is a powder room.
In the basement there is a huge steel support beam that runs across the house horizontally, but this wall is not on top of it at all.
EDIT: Should be more clear...There is a basement under this floor, and a 2nd floor above this floor. This is our 1st floor.
Thanks!
agentphish is offline   Reply With Quote
Old 04-16-2011, 10:03 PM   #2
Learning by Doing
Leah Frances's Avatar
Good job on the pics! I won't speculate on the structural aspect - 'cause I don't know what I'm talking about. But at very least you'll have to move the electric circuit that is in the wall - switches, etc. And you'll have to make sure you don't have any plumbing running in it.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 04-16-2011, 10:16 PM   #3
Yes, I am comfortable with electric and as best we can tell there is no plumbing running up it from below. E
Old 04-16-2011, 11:32 PM   #4
Registered User
Rewards Points: 5,472
I'd pull the drywall ceiling in the closet only. Check joist direction. FIRST, if basement exposed, any HVAC or plumbing lines going up? Doubled joist directly below? Relate.
Gary
Replacing load bearing wall KarlJay Building & Construction 4 12-27-2013 03:44 PM
Is this wall bearing? adamgram Building & Construction 15 01-18-2011 09:32 PM
Removing a wall with no ceiling joist above it i77ac_10 Building & Construction 2 01-05-2011 12:30 PM
Load Bearing Wall? Traybae Remodeling 3 11-05-2006 01:39 PM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 01:01 PM
