Need Help With Stair Trim - Carpentry - DIY Chatroom Home Improvement Forum
Old 07-15-2012, 11:15 AM   #1
Woody10's Avatar
Rewards Points: 29
I am about as handy as a sack full of yogurt. I am trying to trim down the side of my stairs and have no idea how to cut the pieces of trim to fit. I have tried angles galore and just can't figure it out.
Could somebody lend me a hand?
My Stairs
The Trim
My Problem with Basic Math
Woody10 is offline   Reply With Quote
Old 07-15-2012, 11:24 AM   #2
Rewards Points: 13,446
That is some funky looking stairs you have there.
No hand railings, not even close to code on run and rise.
Why in the world is there carpet where they should have been a solid wood cap on that wall so railings could be attached?
Just adding that outside corner molding is not even covering up the carpet edge.
Old 07-15-2012, 11:31 AM   #3
Using one of these tool will make it a simple job to cut it right the first time.
http://www.rockler.com/product.cfm?s...LER&page=22579
Looks like for some unknown reason you trying to cut a compound angle.
You only need one angle to make that cut.
Old 07-15-2012, 08:14 PM   #4
Stairguy
Millertyme's Avatar
Rewards Points: 508
That top step looks a little screwy.
It's probably about a 20degree angle. Do you have a miter saw?
Millertyme is offline   Reply With Quote
Old 07-17-2012, 01:30 PM   #5
Retired Cabinetmaker
woody4249's Avatar
Rewards Points: 156
Like Joe said..........."that's some funky looking stairs"
I have to assume that the "Compound cut" is a mistake.
First determine the type and profile size of the material you want to use.
To determine the angle cut at the bottom of the stairs
You can use a piece of cardboard and mark out the angle by placing it against the bottom part of the stringer wall and on the floor and accurately running a pencil along the two surfaces at the intersection.
Your drawing should look like the one below.
From the intersecting point, set up a pair of compasses to any dimension say 3" and strike an ark on both lines shown as distance "A"
Then reposition your compass point on this new point [marked with an x]
and draw another ark. Do this again on the other x. Draw a straight line from the intersection point and your point where the two arks bisect.
This is the angle you set your miter saw up to.
Mike
"I'm not as green as I am cabbage looking"
woody4249 is offline   Reply With Quote
New Roof but Fascia Trim Board Rotting ein0801 Roofing/Siding 6 07-15-2012 12:21 AM
Trim / Finish Carpentry around stair stringers cjdavia Carpentry 16 11-15-2011 10:40 AM
How to install trim around stair treads jingle Carpentry 5 09-24-2011 06:03 PM
How do I install trim around stair treads? JayBird Carpentry 22 08-07-2010 04:16 PM
Interior Door Trim (am I the only one that does this?) javan Carpentry 17 08-14-2008 03:19 PM
