Need Help. Skirt Board For Stairs? - Carpentry - DIY Chatroom Home Improvement Forum
Old 02-21-2011, 03:48 PM   #1
Question
Need help. Skirt board for stairs?
Hi,
I'm at the final stages of my basement finishing project. I'm trying to figure out how to improve the look of my old, existing stairs. I know I need to install some sort of trim or skirt board, but can't for the life of me figure out what will look good.
The gap between the stringer and the wall ranges from almost nothing, up to about 1/2". I think I need to make a skirt board and attach that to the existing stringer and then cap it off with a 1x to fill the gap between the skirt and wall.
Can anyone confirm this or provide me with an easy alternative. The stairs will be carpeted.
Thanks,
Mike
Need help. Skirt board for stairs?-img_20110209_010713.jpg   Need help. Skirt board for stairs?-img_20110209_010718.jpg   Need help. Skirt board for stairs?-img_20110209_010725.jpg   Need help. Skirt board for stairs?-img_20110209_010732.jpg
met152 is offline   Reply With Quote
Old 02-21-2011, 04:36 PM   #2
Ole Wood Worker
BigJim's Avatar
Rewards Points: 118
To put skirt boards in is not an easy fix. One thing you have on your side is the treads are painted so fixing the gaps that you will have after cutting and installing a skirt board will be easy. You need to remove the angle 2Xs, cut a skirt board to fit the top and bottom of the stairs.
Sit the board down on the edges of the treads and make a mark. Cut that part of the nosing off from the mark to the wall on all treads. Put the skirt board back in place after notching the treads. Mark each skirt to fit on the treads and cut. I am sure there will be a few gaps when the skirts are installed. Just caulk and paint and there you have it. If you want it to look better after the skirts, install 1 1/8 inch basecap on top of the skirts.
New members: Please consider adding your location to your profile.
He is no fool who gives what he cannot keep, to gain what he cannot lose.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 02-21-2011, 07:51 PM   #3
Registered User
Rewards Points: 4,920
Stairway skirt board template - easy
Gary
Old 02-21-2011, 11:46 PM   #4
Ole Wood Worker
BigJim's Avatar
Rewards Points: 118
Originally Posted by GBR in WA View Post
That is a neat and easy way to cut the skirt, I like that.
Jim
Old 02-22-2011, 02:32 PM   #5
Thanks so much!
I followed the instructions that CVGFir posted in that thread. I was able to cut the skirts last night. Much better look than before. Just needs some paint, caulking and a cap.
Thanks.
Mike
The Following User Says Thank You to met152 For This Useful Post:
Gary in WA (02-22-2011)
Old 02-22-2011, 03:31 PM   #6
Registered User
You are welcome from the DIYChatroom, used the "Search" at the top of page....
Gary
Stairway skirt board template - easy Richo Carpentry 14 08-26-2011 05:03 PM
Trouble with Stair skirt board. Need Advice and help. PIC!! bfan781 Carpentry 10 12-04-2010 01:09 AM
Basement Stair Fininshing Advice / Skirt Board DoubleK Building & Construction 1 10-23-2009 09:48 AM
luxaire/york 33109167000 furnace board replacement check HVAC 18 07-13-2009 11:03 AM
Small Gaps between tread & skirt board jcpullen Carpentry 14 08-26-2008 02:06 PM
