Need Help Making Radiator Covers - Carpentry - Page 2 - DIY Chatroom Home Improvement Forum
Old 11-20-2007, 07:48 PM   #16
mackem's Avatar
Originally Posted by RemodelMan View Post
Figure out a way to secure the cover/cabinet to the wall, in order to prevent the entire cabinet from falling forward should someone sit or stand upon it to operate the window(s) or blinds etc.
I prefer to make a two-part beveled ledger that will accept the mate by lifting the entire cabinet above and down upon it. Just rip a 1" X 3" board at a 22.5 degree angle. Then attach one piece to the botom of the cover flush to the wall side and the other to the wall. This creates a simple matching pair.
This simple joinery method allows for easy removal of the cabinet/cover by lifting it up and off when it's necessary to bleed the radiator.
Secondly, consider leaving slots or a gap between the wall and backside of the radiator especially if it is located in front of a window.
This method of fixing is called a "French Cleat".
mackem is offline   Reply With Quote
Old 04-08-2011, 12:23 PM   #17
Wood Baseboard Radiator Covers
If you look at the ugly steel covers it seems that there is a reason for their configuration. There is an opening at the bottom and an opening at the top. This allows for convection, and therefore a more rapid exchange of heat from the water/pipe to the air. They make taller covers for drafty rooms -i guess it is for more convection. Unless someone throws out a better idea, I am going to make wood covers that mimic the taller steel design because we have a drafty room to heat.
Mindaugas is offline   Reply With Quote
Making carriage style garage doors Jill General DIY Discussions 16 10-31-2012 06:06 PM
GE side-by-side making a whining noise jkrodger Appliances 2 09-11-2007 02:45 PM
Making a dust collector run with a switch Electricnewbie Electrical 7 07-28-2007 12:20 PM
Toilet making Noise DSHMSH Plumbing 1 12-22-2005 04:33 PM
Making bear totum pole Keith of Ronin Landscaping & Lawn Care 2 03-27-2005 01:22 PM
