Need Help Making Radiator Covers - Carpentry - DIY Chatroom Home Improvement Forum
Old 10-30-2007, 08:28 PM   #1
Need help making radiator covers
Anyone has ever made nice radiator covers? Any ideas on how to build them? Thanks
Atlantic West, I'm sure you've done a few . I would like to build something like this:
helpless handyman is offline   Reply With Quote
Old 11-05-2007, 11:00 PM   #2
Rewards Points: 5,336
You have a picture to work with, what do you need? Just modify it to the size you need for your radiators.
Ron
Old 11-06-2007, 08:20 AM   #3
I was thinking about doing something like that for my baseboard heaters. The ones that you can buy are downright expensive!
perpetual98 is offline   Reply With Quote
Old 11-06-2007, 10:24 AM   #4
What's the question? Joinery methods? Depends on your skills and your tools. It's basically a face-frame with boards nailed to the inside of it for slats, and a top screwed on. You can assemble your face frame with biscuits, pocket screws, dowels, or mortise and tenon.
NateHanson is offline   Reply With Quote
Old 11-07-2007, 12:04 AM   #5
Figure out a way to secure the cover/cabinet to the wall, in order to prevent the entire cabinet from falling forward should someone sit or stand upon it to operate the window(s) or blinds etc.
I prefer to make a two-part beveled ledger that will accept the mate by lifting the entire cabinet above and down upon it. Just rip a 1" X 3" board at a 22.5 degree angle. Then attach one piece to the botom of the cover flush to the wall side and the other to the wall. This creates a simple matching pair.
This simple joinery method allows for easy removal of the cabinet/cover by lifting it up and off when it's necessary to bleed the radiator.
Secondly, consider leaving slots or a gap between the wall and backside of the radiator especially if it is located in front of a window.
RemodelMan is offline   Reply With Quote
Old 11-07-2007, 10:10 AM   #6
Thanks guys!
Old 11-07-2007, 10:21 AM   #7
help tile shower in basement motar was attatched to concrete block on with slick 2x2 tile on walls how do i get off with out destroying wall
creeda is offline   Reply With Quote
Old 11-07-2007, 12:17 PM   #8
Firefighter/Paramedic
tyler101's Avatar
http://www.thisoldhouse.com/toh/vide...053533,00.html
tyler101 is offline   Reply With Quote
Old 11-07-2007, 01:10 PM   #9
Just a random thought ... how efficient is using wood opposed to metal? What kind of heat loss are we talking about and will it be noticeable?
rolldodge is offline   Reply With Quote
Old 11-07-2007, 01:37 PM   #10
Wide flat chisel, safety attire and patience.
Ron
Old 11-07-2007, 02:56 PM   #11
What do you mean by "heat loss"? The material of the cover will have no bearing on how much heat is transferred to the room from the radiator.
In theory, it could change how FAST the heat is transfered to the room.
A thin convoluted metal cover would quickly conduct heat to the room air. A wood cover would heat up, absorbing a small amount of heat, and ultimately radiate that heat back into the room when the radiator cycled off. A really heavy metal cover would absorb a lot of heat when the radiator warmed up, so it would take longer for the room to get warm initially, but it would provide heat long after the radiator cycled off.
But in practical terms (your not going to make a 500 pound iron radiator cover) there's no difference in what materials you use. Just make sure it's vented, and allow for some movement in the wood if that's what you use.
Old 11-07-2007, 03:00 PM   #12
Well put Nate.
Old 11-07-2007, 06:19 PM   #13
You might wish to rent a pneumatic tile chiseler if the tiles are mortared on.
Typically, the chiseler is used to loosen stubborn floor tiles. Make sure the chisel has been ground sharp before leaving the shop and ask for an additional chisel while your there.
Lastly, it helps to confine the dust if you spray the wall occasionally during the process.
Old 11-08-2007, 11:19 AM   #14
Question answered - Thanks Nate. I was just curious to see if wood was less efficient, and if so how much. i didn't imagine there would be a that much of a difference though.
Old 11-17-2007, 09:39 PM   #15
Custom Cabinet Maker
I used the punched out metal sheet, which comes in many different patterns, set into a wooden face frame. This allows free movement of heat and still makes a very nice cover
skymaster is offline   Reply With Quote
Making carriage style garage doors Jill General DIY Discussions 16 10-31-2012 06:06 PM
GE side-by-side making a whining noise jkrodger Appliances 2 09-11-2007 02:45 PM
Making a dust collector run with a switch Electricnewbie Electrical 7 07-28-2007 12:20 PM
Toilet making Noise DSHMSH Plumbing 1 12-22-2005 04:33 PM
Making bear totum pole Keith of Ronin Landscaping & Lawn Care 2 03-27-2005 01:22 PM
