Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 04-26-2005, 05:48 PM   #1
Need help with framing roof for sunroom
Hello, and I'm new here and I hope I can explain this correctly.
I am in the process of designing a four season porch. The demensions is 12'6" x 14'. I have the slab all ready poured for it. I just need to frame it up. I can do just about everything else, but I ran into one problem.
My current house has roof trusses. I want to build this sunroom with a valted ceiling. I talked to the building inspector and he requires that I use 2 x 12's for the roof joists for the proper "R" value. Well, I need to tie into my current roof trusses. Using 2 x 12's would raise the roof and the soffet 3". This would make the soffet jog up at the transition of where the sunroom and house are.
My question is what can I do to use 2 x 12's and still match up my existing soffet and overhang so they match?
Any help would be well worth it.
Thanks,
diehard
diehard_1955 is offline   Reply With Quote
Old 04-27-2005, 11:24 PM   #2
Contractor
diehard, I find it difficult to believe that 'R' value has anything to do with your structural plans.
Teetorbilt is offline   Reply With Quote
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing 4 11-19-2006 07:17 AM
1950's Roof Framing Strength KempLN Building & Construction 21 06-17-2006 11:06 AM
Framing Attic Walls but Roof Has SAG! luckestryke Building & Construction 1 04-27-2006 09:40 PM
framing a roof on stone outbuilding whoshowie Roofing 3 01-19-2006 07:41 AM
Sagging roof - framing question G.P. Carpentry 7 12-26-2005 05:32 AM
