Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 11-15-2009, 01:12 PM   #31
Framing Contractor
Need help figuring out rafter lengths.
Originally Posted by CleIndiana View Post
Hopefully your still following this Joe, because I just came up with a new idea. I was driving around my neighbor hood and saw a house with the same style porch that i want. From what I could tell you would build up and off the existing ridge board. so the way it looked to me was that the whole front section of the roof is lifted about a couple of feet and that seemed to be how they got the right pitch. I wish I could have a drawing for you but sketch it isnt letting me open your drawing that you had fr me.
I know exactly what you're talking about. I was going to suggest that before, but I thought you have an EL shaped roof. I extend front ridges all the time when doing dormers. If you don't have to deal with another roof in the back, raising the front ridge will work fine. I will draw your roof for you so that you can have the porch girder the same height as the top plate. I will extend your front ridge to make the porch roof a 3/12.
Joe Carola
Joe Carola is offline   Reply With Quote
Old 11-15-2009, 01:31 PM   #32
Your the man Joe, as far as the garage I would just build around it like the existing roof is correct? and also since I'm spanning farther then before do I need to switch to 2x8 or 2x10?
the main house is straight with two ridges and gable ends, and then the garage sit at a 90 to the house on the far left side and that roof has two ridges and is gabled as well.
It looks just like that guys picture I posted on the first page.
CleIndiana is offline   Reply With Quote
Old 11-15-2009, 01:46 PM   #33
Framing Contractor
Here's the drawing.
Joe Carola
Old 11-15-2009, 05:32 PM   #34
Thanks for the drawing, I think this is the way I should go. The only thing that may give me trouble is that sky light. Also since this is pretty much a new roof system on the front should I go with a bigger rafter or just stay with the 2x6?
Old 11-15-2009, 09:21 PM   #35
Framing Contractor
The skylight won't give you trouble at all. It's just more framing involved. If it doesn't work out with the new roof and keeping the same opening with framing a shaft and giving you enough light, you will have to reframe the existing opening and sheetrock/tape/spackle/paint..etc.
You might have to depending on snow loads in your area. You really have to check with an Architect or Engineer about the rafters and ridge. I';m just drawing what you can do. If you would need to use 2x8's I will draw 2x8's for you. That will change things a little, but not much. You also would have to install collar ties from the existing ridge to the new shed rafters.
Joe Carola
Old 11-15-2009, 10:24 PM   #36
Thanks Joe Ill get with an engineer about the loads. Will I still need that collar if use the 2x8 or is it there for more support to the new roof?
Old 11-16-2009, 04:18 PM   #37
Framing Contractor
Maybe, maybe not. Depends on what the Engineer says. He might say you don't need the collar ties. That total length can be done on one shot. If youb use a 2x6, the kneewall might have to take the weight at that point. If so you have to make sure any headers you have in your back wall can handle the weight. You have a few options that will work for you.
You are going to have a funky spot on your roof on the other side of the perpendicular roof you have a couple options there also how to frame that. Do you have the height and distance that top ridge is coming down from the main roof?
Joe Carola
Old 11-16-2009, 06:47 PM   #38
If you talking about were the garage ridge meets the main roof yes because the garage ridge sits below the main roof by a ft ft and half. To me it would seem that around that area i would just be building around the garage roof. Or I could stop at the garages ridge line and just flash in the side of the new roof.
If not then I'm clueless
More On This Topic
Whether your family will be comfortable on your porch depends on whether you've built it at a proper level. A level porch helps furniture stay in place and keeps glasses from sliding off your table onto the ground. You need to know how to find and... Read More »
I'm Tom Shean and today on behalf of Expert Village I'm going to show you how to install a metal roof. The valley flashing is laid between two valley battens and fastened through the top flange. Where the valley terminates at a fascia, the valley... Read More »
The outside roof pitch on your home can be made more attractive by increasing the pitch of the roof. Increasing the roof pitch also provides a more efficient way for rain and snow to drain more easily off of the roof. Read on to learn more. Read More »
There are still many examples of Victorian houses in the United States, some of which are in great repair, while others are fixer-uppers. They were built in the nineteenth century, from about 1830. If you're interested in history and these lovely homes... Read More »
During the winter months heavy snowfall can cause a buildup of snow on your roof. The weight of the snow can cause damage to your roof, or even cause it to collapse. Follow these guidelines to learn how to keep snow off your roof for wintertime... Read More »
how to find rafter lengths countryboy Building & Construction 3 12-07-2008 07:25 PM
Moving Attic Access -- Same Rafter or Different ?? wrldruler Carpentry 1 10-19-2008 07:03 PM
need some rafter help feralfreak Carpentry 5 07-30-2008 07:48 AM
rafter questions - structural rtoni Carpentry 11 09-13-2007 06:40 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
