Need Help With Deck Ledger - Carpentry - DIY Chatroom Home Improvement Forum
Old 09-29-2005, 01:04 PM   #1
need help with deck ledger
I am building a deck and I need to figure out how to install a ledger around my nook. it's lies along a 12' brick wall, it has three faces with the two sides angled back to the wall. I want the ledger to run the full length of the 12' wall.
weekender is offline   Reply With Quote
Old 09-29-2005, 08:16 PM   #2
Carpenter
DecksEtc's Avatar
Attach it the same as if it were a straight wall. Just attach 3 separate boards for the ledger. The joists you run off the ledger at the angled sections will be angled to match to angle of the wall. hen your deck boards will be cut to conform to the angles of the wall.
Was that clear enough to help you?
Terry
DECKS Etc.
GardenStructure.com
DecksEtc is offline   Reply With Quote
Old 09-30-2005, 07:36 AM   #3
Old 10-02-2005, 10:32 PM   #4
Carpenter
DecksEtc's Avatar
No problem.
Terry
DECKS Etc.
GardenStructure.com
Attaching deck ledger to cantilever ram80ran Building & Construction 13 04-18-2009 12:29 PM
What size deck is 'good' for our situation? curls00 Carpentry 20 09-08-2007 07:12 PM
Deck ledger/carriage bolt question colaminecanary Building & Construction 9 07-31-2007 07:16 AM
Installing deck ledger board over foam board? RickT Building & Construction 5 11-06-2006 10:50 PM
