Need Help Cutting A "triangle" - Carpentry - DIY Chatroom Home Improvement Forum
Old 12-28-2007, 09:52 AM   #1
Need help cutting a "triangle"
How do you cut both the 45 degree angles using a mitre saw?
Thanks for any help.
whippet100 is offline   Reply With Quote
Old 12-28-2007, 11:18 AM   #2
A little more information would help. What are you making? What are the lengths of your sides? I'm guessing by your question that you're making a right triangle, with interior angles of 90, 45, 45?
XSleeper is offline   Reply With Quote
Old 12-28-2007, 01:24 PM   #3
Rewards Points: 150
Set the saw to 45, cut a 45 on one end of longer stock. Now, flip the piece to other side of blade, and you can cut off your triangle.
If your stock is too short to give proper support for second miter, you can support the second cut by using cutoff from first miter to clamp the piece to fence.
scorrpio is offline   Reply With Quote
Cutting Duct ADKstorm HVAC 10 01-23-2011 01:30 AM
Cutting Tile rookie1 Remodeling 9 10-22-2007 04:25 PM
cutting glass victor General DIY Discussions 2 08-06-2007 11:51 PM
Kitchen Sink/Counter cutting help? Lambo Plumbing 7 06-08-2006 07:31 AM
Cutting into the basement floor hallbum Remodeling 3 10-07-2005 10:14 PM
