Need Help With Compound Miter Saw - Carpentry - DIY Chatroom Home Improvement Forum
Old 04-06-2012, 10:04 PM   #1
Need Help with Compound Miter Saw
I have a 10" Ryobi Compound Miter Saw. It cuts perfectly square vertically. When I bevel the saw though something goes awry. The cut is no longer square.
I am doing 5.25" tall baseboards, so I have to lay it flat. The top of boards line up but all of my inside corners do not line up. The tops are perfect but then there is a gap at the bottom.
I have tried adjusting the fence but it doesn't help, any ideas?
krombie19 is offline   Reply With Quote
Old 04-06-2012, 11:46 PM   #2
Rewards Points: 512
cope your cuts, make sure the base goes in tight
princelake is offline   Reply With Quote
Old 04-07-2012, 12:06 AM   #3
Rewards Points: 14,312
How do you know is the saw and not the floor that's off.
Prince is right, coping will always give you a tighter joint.
Old 04-07-2012, 04:57 AM   #4
Walls may not be square.
Make sure your piece is flat on the base of the saw.
Jerk is offline   Reply With Quote
Old 04-07-2012, 05:15 AM   #5
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Check the angle of the actual wall corners you are installing on; Use a speed square to see if it is an actual 90 degree angle, or if it is "off".
- Build Well -
Old 04-07-2012, 05:48 AM   #6
DIY staff
Rewards Points: 7,174
Gap at the bottom of a baseboard---usual cause---drywall taper at the bottom---wall is not flat--add shim or screw to keep the baseboard flat.
Old 04-07-2012, 06:31 AM   #7
Not so new
12penny's Avatar
Rewards Points: 520
+ 1
12penny is offline   Reply With Quote
The Following User Says Thank You to 12penny For This Useful Post:
oh'mike (04-07-2012)
Old 04-07-2012, 07:52 AM   #8
Thanks for the response but I have used a square to check the cut pieces and the vertical cut is spot on. When I bevel the cut it fades away from the line.
Old 04-07-2012, 09:43 AM   #9
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,348
it can be a few things.... the saws fence might not be perfectly square which causes the cut to be off by one degree when you cut on a 45, there could also be a buildup of dust inside the table which causes the table to tilt when you swing it around angles.. very common if you dont blow the dust out of the saw on a regular basis
the wall may not be square.. there might be a build up of mud on the wall that needs to be scraped off before the base goes on.. i always keep a scrap peice of trim for checking angles . do to the build up of mud on inside corners and the thickness of the corner bead on outside angles the actual cut angle required is rarely exactly 45 degrees. i cut all my inside corners on 44 degrees so the face of the joint is tight , for outside mitres i cut 90 deg corners on 46 degrees to keep the face nice and tight also.
trim requires patience especially when your new to it or dont do much of it, i lead the trim installs on all the houses we renovate or build. the painters are kinda shocked that i go a little slower than most trim guys they see, however their even more shocked when they only need 1 tube of dap for 2 rooms of trim for where the trim meets the drywall as opposed to upwards of 3 tubes per single room
woodworkbykirk is offline   Reply With Quote
Old 04-07-2012, 10:22 AM   #10
Stairguy
Millertyme's Avatar
Rewards Points: 508
The reason this is probably happening is because there is a plastic throat plate on the table of the saw. they are usually a little flimsy. When you cut material, usually on a beveled 45, the saw blade will tend to push the plastic plate down making an out of square cut. So to avoid this, lay down a sacrificial board on top of the saw and then make your cuts on top of this.
Millertyme is offline   Reply With Quote
The Following User Says Thank You to Millertyme For This Useful Post:
kwikfishron (04-14-2012)
Old 04-07-2012, 08:44 PM   #11
Old School
Willie T's Avatar
Are you always cutting with the FACE of the base upward?
Do NOT try to cut the base with the FACE (front side) laying down on the saw table.
And cut slowly, always using a good, sharp blade........ Many dummies think that since it is often called a "chop" saw, that you are supposed to slam the saw down quickly, "chopping" the board in half. This is just begging for a lousy cut.... and it will eventually ruin your saw blade, if not the whole saw.
And let the blade come to a FULL stop before lifting it back up past what you just cut.
Willie T
Old 04-14-2012, 07:31 PM   #12
Make sure that the saw is set up proper. Most saws have different adjustments pertaining to both the fence and blade itself so you can keep everything square. Check the instruction bbok that came with the saw, or go to ryobi's web and see if they have instructions you can download. Also, the walls are rarely square.
Good lock and have fun.
Glenn12 is offline   Reply With Quote
Compound miter cut trim question robosapien Carpentry 3 07-09-2010 08:46 PM
Slide compound miter saw dinotoad Tools 11 02-10-2010 08:45 PM
Compound miter saw wont shut off kscudebec Tools 8 02-06-2009 08:00 AM
Suitable Miter Saw stand for 10" Sliding Makita compound saw zappy Carpentry 3 07-16-2008 07:33 PM
Using Compound Miter Saw Loman43 Carpentry 12 01-01-2008 01:36 PM
