Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 04-19-2010, 10:45 PM   #1
Need help with canopy (wood and base)
I need to build something like this.
I was planning on just using pressure treated 4x4 posts and some type of trim board for the tops. I'm not sure what type of wood actual lumber yards carry. I'm only familiar with the big box stores. The wood needs to be painted and needs to have a finished look. The only posts I could find at the big box stores are cedar and pressure treated. Do the lumber yards carry 4x4 posts that are not pressure treated or of a higher quality wood? Also, what type of wood would you recommend for the top boards. I'm thinking about using 1x6 pine or just using some type of decking wood.
The final question has to do with the base. Do you have any suggestions as far as the base goes. I need something that can weigh it down, so it doesn't blow over from wind. I'm thinking about some kind of boot (possibly metal) that bolts to it.
Any help would be appreciated.
Thank you
bluefitness is offline   Reply With Quote
Old 04-20-2010, 11:11 PM   #2
Pro
Nostco's Avatar
4x4's composite post sleeves
http://www.verandapremiumfence.com/postsleeve.htm
Check these composite manufacturers:
http://www.geodeck.com/
http://www.fiberondecking.com/
http://www.azek.com/
As for the footings for the posts...will this be temporary or permanent? If temporary, they have temporary footings for posts...Can't recall the name but Landscape guys/Deck guys would know. You can find them at the Big Box Stores.
Let me know if none of the above actually helped
Nostco is offline   Reply With Quote
Old 04-20-2010, 11:15 PM   #3
It will be a temporary structure that needs to be moved. Are the footings you are referring to the concrete ones? I'll look at the box stores to see if I can find anything. If you find out what they are called, let me know.
Old 04-25-2010, 03:44 PM   #4
Big box stores carry 4x4 doug fir posts. You can run them through a planer or sand them for the required look.
Ron
Building a base for my wood stove Verbose Building & Construction 1 10-11-2009 08:06 PM
protective concrete base for wood stove standingeyes General Discussion 2 04-26-2009 11:01 AM
Base Structure for Shed jasoncw Building & Construction 4 04-16-2009 08:08 AM
Laminate wood floor layout questions nathan.tran Flooring 4 08-30-2008 11:56 PM
Replacing Porch Column base, what wood to use? Shamus Building & Construction 7 05-31-2008 01:29 PM
