Need Help Building Rear Speaker Stands - Carpentry - DIY Chatroom Home Improvement Forum
Old 04-20-2009, 05:36 PM   #1
Rewards Points: 77
need help building rear speaker stands
Any plans or pics would be appreciated I am looking to build rear speaker stands for my surround sound looking for something that would hide the wires and looke clean.
bowanna03 is offline   Reply With Quote
Old 04-22-2009, 07:25 PM   #2
Rewards Points: 5,336
This is impossible to answer without pictures of the space the speakers occupy.
Ron
Old 04-23-2009, 06:51 AM   #3
Rewards Points: 77
have no pics it is a very open space I want to put them on each side of the couch I was thinking of flush mounting them to the wall but never ran wires through the wall before thanks for the help
Old 04-23-2009, 08:33 AM   #4
Easiest way to run speaker wires along the wall, but hidden would be to remove the base molding and cut a groove in the drywall for the wires. There might even be an open space at the bottom of the wall you can use. You just need to be very careful about the nails you put in to reinstall the molding.
Ron
Old 04-23-2009, 09:10 AM   #5
LeviDIY's Avatar
Rewards Points: 252
Once the wire is in the drywall groove, I'm assuming go right over with joint compound, primer, and paint?
LeviDIY is offline   Reply With Quote
Old 04-23-2009, 09:53 AM   #6
I wouldn't do that. You just staple the wire in the groove and put back the molding.
Ron
Old 04-23-2009, 09:55 AM   #7
LeviDIY's Avatar
Rewards Points: 252
Oh my mistake... I didn't read close enough... you were referring to running along the bottom of the wall, I was wondering what happens once you reach the point in the wall you want to lift the speaker up vertically (if you are mounting on the wall I guess)? Sorry to hijack the post...
Old 04-23-2009, 10:03 AM   #8
If you want to install the speaker up on the wall ,you would get to the bay you want, cut a hole for the oulet box and snake the wires up from the floor.
Ron
Old 04-23-2009, 10:19 AM   #9
LeviDIY's Avatar
Rewards Points: 252
Much obliged.
Running speaker wires... MT Stringer Home Theater 9 01-18-2009 08:26 PM
NEC uses building size?????? hhiibel Electrical 14 08-08-2008 12:19 PM
Building a movable garden shed/greenhouse gardener Building & Construction 1 06-13-2008 04:47 PM
International building code and permits rforsha Building & Construction 4 08-28-2006 06:35 PM
