Need Crown Install Expertise (pic's) - Carpentry - DIY Chatroom Home Improvement Forum
Old 05-25-2008, 12:50 PM   #1
Need crown install expertise (pic's)
Wife would like some crown installed in the master bath room. Lot's of angles but certainly something I can do except I don't know how to approach this one spot. Kind of an odd arrangment where the walls and the skylight come together. Run it around and the crown would stick out. The other option would be to do returns just prior to the funky angle but that would just call attention to it. Any ideas? I told the wife I won't do the project until I figure this out first.
Rohey is offline   Reply With Quote
Old 05-25-2008, 12:57 PM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
My First suggestion would be to stop the lengths of crown on each wall, just short of the opened area, and do self-returns on each ends.
There are some picture examples on these links:
http://www.altereagle.com/5_How_to_insta.html
http://store.balmer.com/howto/ideas/g5-return.html
- Build Well -
Old 05-25-2008, 03:48 PM   #3
BUILDER / REMODELING CONT
buletbob's Avatar
I would continue to wrap the corner with the crown. What are you going to do when you run into the left short side wall . it appears that the ceiling is sloped. are you going to stop at that point.????. anyway what I have done in the past is keep your horizontal lines lined up around the wall, at the sloped ceiling area I riped and laid a piece of window stool on top of the crown so the bottom profile stickes past the top edge of the crown about 1/8" to create another shadow line. when you come to the outside corner of the crown miter the sill back into the sloped skylight wall. I fell that would be another option. in addition to what atlantic suggested.
Old 05-25-2008, 03:57 PM   #4
Jay123's Avatar
I think I would try to wrap the crown. I've got to go out to dinner but I'll draw the little block that I would install over the top of the "open air" crown tomorrow and post.
J
Need crown install expertise (pic's)-crown-before.jpg   Need crown install expertise (pic's)-crown-line-draw..jpg   Need crown install expertise (pic's)-crown-render1.jpg
Jay123 is offline   Reply With Quote
Old 05-25-2008, 04:55 PM   #5
You are my hero!!!!Been stumped with crown molding myself. The angles are killing me. That first web site is very helpful . Thanks for sharing it.
rong1 is offline   Reply With Quote
Old 05-26-2008, 08:01 AM   #6
Jay123's Avatar
Here are some shots with a "cap" over the crown.
J
Need crown install expertise (pic's)-crown-top-view2clr.jpg   Need crown install expertise (pic's)-crown-top-view2rndr.jpg   Need crown install expertise (pic's)-top-clr.jpg   Need crown install expertise (pic's)-top-clr-rndr.jpg   Need crown install expertise (pic's)-crown-render1-top2.jpg
Old 05-26-2008, 08:13 AM   #7
Jay123's Avatar
Here's a couple pics showing where I had to do something a little similar to a basement staircase.
In the first picture you can see on where the crown moulding at the tops of the columns extend beyond the ceiling and we made caps for them.
In this case we had to cap them because every time you walked down the stairs you would be looking right into the top of the crown moulding.
In the second pic you can see where we did a crown return to the left of the stair case.
J
Need crown install expertise (pic's)-ch-stairs1.jpg   Need crown install expertise (pic's)-ch-stairs2.jpg
Old 05-26-2008, 11:07 AM   #8
Thanks for the ideas, pics and drawings! Jay, I really like your cap idea.......This forum rocks!
I thinking that a low profile piece "above" the cap may further soften the look. How about this run the crown just as you have drawm, insert the cap "inside" the crown flush with the top and then maybe a piece of base board laying back down on top of the cap (with lower profile to the front and higher profile to the back). Simple return to finish the end. I don't have the drawing skills Jay does but I think you all can follow my thoughts. It will be painted crown so it should blend in nicely with the ceiling.....or maybe something with a higher profile? or ???????
Old 05-26-2008, 11:16 AM   #9
Jay123's Avatar
Your welcome Rohey. Your idea to use something like baseboard would work well I think.
After you get the crown installed, you'll just have to putz (that's a professional term ) around with it until you come out with something that suits you...I do it all the time.
J
Old 05-26-2008, 11:29 AM   #10
Jay123's Avatar
Here's a couple of shots with a 3/8" (instead of 3/4") profile. I painted your crown and door casing for you too.
J
Need crown install expertise (pic's)-crown-lwr-prof1.jpg   Need crown install expertise (pic's)-crown-lwr-prof2.jpg
Old 06-01-2008, 10:50 PM   #11
get rid of the wallpaper first
amdspitfire is offline   Reply With Quote
Old 06-02-2008, 03:34 PM   #12
pwhoolboom's Avatar
That looks awesome Jay...Just gave me some ideas for my funky house....
pwhoolboom is offline   Reply With Quote
Crown molding termination at tile Stickboy Carpentry 4 12-26-2011 10:35 PM
crown molding meets window trim sonofthetonsured Carpentry 13 03-19-2011 12:33 PM
Repairing Bad Crown Moulding Install jirishboy Carpentry 10 10-02-2008 09:05 PM
No experience, should I attempt crown molding? kristin Carpentry 7 02-03-2007 01:34 PM
Crown Caulking Not Sure Carpentry 3 08-18-2006 09:40 PM
