Need To Build Something To Cover My Sump Pump - Carpentry - DIY Chatroom Home Improvement Forum
Old 04-07-2009, 08:49 AM   #1
Rewards Points: 77
need to build something to cover my sump pump
My sump pump runs once a minute and need to make something to cover it to insulate and quiet it down. the constant running of the pump is annoying and can be heard two stories up any help would be appreciated.
bowanna03 is offline   Reply With Quote
Old 04-07-2009, 09:16 AM   #2
Build a box & use hard styro insulation to stop the noise
Make sure the noise isn't from the piping
IE - being conducted thru the house by the plumbing
The box MUST be big enough to not interfere with the operation of the pump
In addition it will need a vent to allow heat to escape
Old 04-07-2009, 11:19 AM   #3
CrossWorks's Avatar
Rewards Points: 150
What Dave said and once more. The key to quieting sound travel is airspace. So if [for example] you build your first box 20" square (outside dimensions) as Dave described and you feel you still have an unexceptable amount of noise, then build another just like it but make it 26" square. This should give you about 3-1/2" of air space all around between boxes and the sound will certainly be trapped in that area. The hole project should take only 1-sheet of 1/2" CDX plywood and 2-sheets of 2'x8' blueboard insulation.
I'll leave the size up to you, but you get the idea.
A great personality will open many doors in life,
but it's your character that keeps them open!
www.crossworksme.com
"Where Every Nail Has a Purpose!"
CrossWorks is offline   Reply With Quote
Old 04-07-2009, 12:08 PM   #4
Rewards Points: 77
Thanks guys I will try this week to get this done I have a really nice long list off stuff to do on this house but do appreciate your help thanks again guys.
Exterior grade sump pump Jeeper1970 Plumbing 11 12-02-2016 10:17 AM
Sump pump pit water level --- problem de12 Plumbing 52 01-14-2016 07:46 AM
Sewer gas smell in basement from sump pump mirage212 Plumbing 15 10-23-2008 06:09 PM
Foundation drain and sump pump slatergrl Plumbing 3 02-10-2008 09:36 AM
sump pump continuing running deck hand Plumbing 2 01-16-2008 04:35 PM
