Need Advise: Planing Large Wood Slab - Carpentry - DIY Chatroom Home Improvement Forum
Old 05-14-2010, 01:56 PM   #1
Need advise: Planing large wood slab
Hi
I'm building a bartop which will be 2" thick and 24" wide and about 8' long.
I want to make it from live edge single slab cut of tree. I can get one dried and ready for working.
The only problem that slab is rough cut. I need to finish it to smooth surface.
Hot do I do it without investing much money? I was thinking about sanding it but it might be too rough for that. Probably better way would be thick-planer it first. But I have no access to such big planer. My friend has 12" planer which will not work out for me. I also can get router.
Can someone advice on this ?
vluzhko is offline   Reply With Quote
Old 05-14-2010, 02:23 PM   #2
How rough is the top? You could build up a tray on the sides and use it as a overarm router slide.
b_corwin is offline   Reply With Quote
Old 05-14-2010, 05:53 PM   #3
Civil Engineer
Rewards Points: 4,762
The lowest cost way to finish it would be with a hand plane. Not a bad idea if you are familiar with use of a plane, you keep it really sharp, and you are not too concerned with having a dead flat top.
If you don't have a plane, or don't know how to use one, take the slab to a mill and pay to have them plane it for you with a machine. Sanding is also possible, but not likely to be work out too well if you sand it yourself using a belt sander or similar. A commercial full width drum sander could do the job.
Old 05-14-2010, 05:55 PM   #4
Stairguy
Millertyme's Avatar
Rewards Points: 508
i would just bring it to any millworking shop. Some may not even charge but if they do it will probably not cost more than $20. A lot of the bigger planners are 24-25".
Millertyme is offline   Reply With Quote
Old 05-14-2010, 06:01 PM   #5
kwikfishron's Avatar
Rewards Points: 576
Find a custom furniture shop in your area. They will have the planer and it shouldn’t cost to much to have them run your board a couple times.
kwikfishron is online now   Reply With Quote
Old 05-14-2010, 07:50 PM   #6
you be mo happy this way
The older I get the better I was
Old 05-15-2010, 11:22 PM   #7
you all were right.
I finally ended up with purchasing SAPELE board from http://www.amwoodinc.com/ (I'm in Canada, Toronto), an guy working there were so kind to plane it for me just for $10 extra fee.
Basically he cut one side of 26" board (so it fits planer), planed both sides and then jointed the cut edge.
So I end up with completely finished bartop with one live edge.
All I need is to probably light sand the top and then stain and finish.
I really did not expect such an attitude to the customer at this location.I highly recommend this place. They are doing only rough wood.
As I'm not carpenter I still need an advice how do I proceed further.
What do I need to finish sanding this board? I can get orbital sander from friend. I also have small Iron-shaped vibrating sander.
And.. I realy have no much info about SAPELE itself. I was told that it is pretty hard wood. And it looks very nice.
Old 05-16-2010, 01:38 PM   #8
Rewards Points: 576
Check out this forum.
http://www.woodworkingtalk.com/
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 02:59 PM
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 09:06 AM
Wood Under Door Sill is Rotted rgmetro Building & Construction 14 11-19-2010 12:24 AM
Extending Concrete Patio Slab bobo Building & Construction 6 04-17-2008 12:17 PM
Wood to Concrete without Drilling MattStata Carpentry 1 04-19-2006 04:16 PM
