Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 03-11-2010, 06:14 PM   #1
Need advice on built-in bookcase
Hi all,
I started knocking out a rather ugly built-in bookcase in my condo with the idea of replacing it with a recessed cabinet for my living room electronics. I confirmed that the wall was deep enough, and it appeared to be hollow behind the bookcase, so I thought it would be fine. Unfortunately, now that the bookcase is partially demolished, I've realized there are ducts that will prevent me from making it as deep as I'd like. I now realize I should have just cut a small piece of drywall out to check before doing anything, but the damage is done. Disclaimer: This is my first condo and I'm pretty new to DIY, so I'm pretty much clueless, but am determined to learn more.
I'm looking for ideas on what to do. I could always rebuild a bookcase the same size as the one I knocked out, but it would be nice to be able to follow through with my original plan. Here are a couple of pictures:
http://tspike.com/pictures/DSC_0012.JPG
http://tspike.com/pictures/DSC_0013.JPG
What would you do?
tspike is offline   Reply With Quote
Old 03-12-2010, 07:06 AM   #2
I would proceed with much caution. I see a fireplace there, indicating that is an outside wall?? Possibly a load bearing wall, with a weakened support structure. Have someone that understands such things have a look-see. You may have to abandon the recessed shelf unit and reinforce those cut studs.
Old 03-12-2010, 11:11 AM   #3
Jay123's Avatar
what he said
Jay123 is offline   Reply With Quote
Old 03-12-2010, 02:48 PM   #4
Send a message via Skype™ to GarageDoorCente
ok for a little bit of advice based off of experience, the bookcase itself is not load bearing. The wall very well may be, but for the most part, you can proceed with taking the bookcase out the rest of the way. It looks to me like dead space, and like the wall that is closest to you, is just there for sheetrock, and to provide a space for your ducting, is the wall that is on the other side of the hole an exterior wall? If so, you're probably playing with a non bearing wall, which would give you more space. But for right now, you can remove the rest of the bookcase, and take more pictures for us to determine what is what, or you can just bring someone you know in to determine that. Once you get it out all the way, and provide detailed pictures, then you can definitely get a more educated plan of what to do.
GarageDoorCente is offline   Reply With Quote
Need advice on remodeling/renovating a prefab (mobile) home countrylifemom Remodeling 47 03-20-2013 10:48 AM
Costs estimate help please for a newbie Basement vs crawl space Cancer Researcher Building & Construction 21 03-30-2012 07:59 AM
built in or built under ovens anastacia Appliances 4 02-09-2010 09:03 AM
built under oven as a built in one? helen30 General Discussion 3 01-27-2008 04:15 PM
I need advice on a flat roof Krissy Roofing 10 12-27-2007 02:55 PM
