Need 4 3/4 Inch Extended Lip Strikeplate - Carpentry - DIY Chatroom Home Improvement Forum
Old 12-22-2009, 11:30 AM   #1
Need 4 3/4 inch extended lip strikeplate
We have an exterior door (Pella) that is in an exterior 6" wall. The interior side of that wall has faux rock, which required some additional trim around the door. This means that the already-wide jamb is even wider. The strike plate is typical, probably an inch and 3/4 or something like that.
I wish I had a better picture, but this shows you the door, and how it swings in, and the rock layer around it, which causes the extra door jamb depth. There is a very thin and narrow trim that covers the edge of the rock.http://picasaweb.google.com/lh/photo...eat=directlink
I hope that link worked.
When we open that door (swinging in), the latch is scraping the jamb and additional trim. It catches on the narrow trim and I just know it's going to rip that piece off if we don't do something.
I have been unable to find an extended lip strikeplate that would cover the entire distance between the edge of the wood and the inside lip that the door closes against, which is 4 5/8".
After searching the web, most strikeplates are measured from the middle of the latch hole to the outer edge of the trim, which I guess would be about 4" measuring by that method. The strikeplates I've seen wrap over the edge a little, which might mean we could take something a little bigger.
But alas, the widest I can find is a 3" strikeplate (measured from the middle of the hole to the edge. That would not cover the trim.
Any ideas?
I'm not handy cutting, bending, and smoothing metal, but it seems like cutting a piece myself might be my only option.
Cecosugi is offline   Reply With Quote
Old 12-22-2009, 12:38 PM   #2
Rewards Points: 404
http://www.don-jo.com/catalog/
http://www.don-jo.com/catalog/pdfs/p54.pdf
High Gear is offline   Reply With Quote
Old 12-22-2009, 12:39 PM   #3
FAB-U-LOUS!! Thank you!
240V 2 pole 1/2 inch GE breakers? Isaac-1 Electrical 12 02-09-2010 11:21 AM
14 inch tank on a 12 inch bowl? jimmybush Plumbing 2 10-02-2009 01:13 PM
First Furnace Install - Need Some Help Getting Started hartkem HVAC 17 10-11-2008 11:55 AM
Water Heater 1/2 inch pipes tke402 Plumbing 7 10-04-2008 11:19 AM
new 41/4 inch tile does not match old 41/4 inch tile sweet123 Flooring 2 12-27-2007 08:53 PM
