Nailing Stain Grade Baseboard - Carpentry - DIY Chatroom Home Improvement Forum
Old 03-31-2010, 07:06 AM   #1
nailing stain grade baseboard
Hello, I'm looking for advice on how best to install stain grade baseboard moulding. (what size nails, etc) It is poplar, with very light stain and will be finished before mounting. I'm replacing trim over already installed carpet if it matters.
Its a small job, 40ft/6 pieces. Can I do this by hand, or is a nailer gun essential?
jeffergj is offline   Reply With Quote
Old 03-31-2010, 10:32 AM   #2
47_47's Avatar
Rewards Points: 62
For this small amount and for 1/2" - 1" thick base moulding, I'd hand drive 6 penny finish nails and use a nail set.
Added: Poplar really doesn't stain well and you may want to predrill holes in hard to get spots or near the end of the moulding.
47_47 is offline   Reply With Quote
Old 03-31-2010, 03:07 PM   #3
There's a pre-stain treatment that opens up the grain (i think) and allows species of wood like poplar to absorb stain. I learned that one the hard way...
conudrum is offline   Reply With Quote
Old 04-01-2010, 07:01 AM   #4
thanks. It is 3/4 thick.
The stain is minwax "natural" and looks great.
I can see where you'd have a problem getting uniform coverage with a darker stain though.
Now I just hate to mark it up with nails..
Old 04-01-2010, 07:16 AM   #5
jlhaslip's Avatar
Rewards Points: 2,798
get a wax stick to fill the nail holes
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is online now   Reply With Quote
Old 04-01-2010, 08:12 PM   #6
Carpenter/Rehabber
moorewarner's Avatar
For nailing, make sure you find your wall studs to nail to, like say with a stud finder, or you will end up with a bunch of additional holes to fill.
Famowood is a great filler for stained wood,
http://www.rockler.com/product.cfm?page=18537
Alternately, if your trim sits tight to the wall (i.e no wall humps or dips) you could attach with construction adhesive.
Also assuming you haven't cut yet, for your inside corners you should cope them (a coping saw is $10 at Lowes or HD), as it will give you a good result regardless of your wall's squareness, they rarely are. On the piece you cope cut the coped end first and then after you have a good cut, cut the other side for your outside corner or splice.
http://www.youtube.com/results?searc...&search=Search
Also a lot of guys like to pre-glue their outside corners, and for that something like this comes in handy,
http://www.amazon.com/dp/B000M3G5EU/...U&linkCode=asn
moorewarner is offline   Reply With Quote
Old 04-01-2010, 09:40 PM   #7
kwikfishron's Avatar
Rewards Points: 814
Nail, Set, Stain, then fill. Get 2 or 3 shades of putty that go from the lightest side to the darkest side of the colors in your stained wood. With a little practice and patience you can knead the different colors together to get a (hopefully) perfect match. Then apply any clear coat finish you want.
kwikfishron is online now   Reply With Quote
Partial hydronic baseboard to radient floor conversion Jeepsail HVAC 4 01-17-2010 04:47 PM
Insulating brick above & close to grade Peter Shepherd Building & Construction 1 09-16-2009 06:41 AM
Exhasted woman & baseboard staining.... Allyson Painting 3 09-06-2009 03:07 PM
Baseboard dilema Allyson Flooring 5 09-04-2009 08:30 AM
Need advice on removing deck stain mwalt2 Painting 7 07-23-2008 05:51 AM
