Nailing Shiplap Interior - Carpentry - DIY Chatroom Home Improvement Forum
Old 01-22-2013, 08:36 AM   #1
Nailing shiplap interior
Hello,
I'm planning on installing 10" pine shiplap board, horizontally on my large gable end interior wall. I'm wondering how to nail it properly. I understand with T+G I can blind nail because the tongue gets captured, but with shiplap it doesn't appear this will be the case. I can blind nail one side, but the other side will be free. What are my options? Face nail the free ends above each overlap, and then fill the nail holes? Seems like a lot of work.
Jeff
aquasport17 is offline   Reply With Quote
Old 01-22-2013, 08:49 AM   #2
Rewards Points: 13,724
http://www.rmfp.com/RMFPPDFS/siding.pdf
Use box or ring shank siding nails.
Do not nail into the laps.
Prefinish the boards before installing.
It's best to premark and drill pilot holes where the nails go so it does not split the board.
Old 01-22-2013, 08:56 AM   #3
Thanks. I did see that article/paper. So that leaves me with nail holes. This is an INTERIOR, and I was hoping NOT to have nail holes. So I suppose I plug/fill them.
I was planning to use an air finish nailer, but it appears that isn't going to work. An alternative would be to use T&G instead so I can blind nail with the finish nailer.
Old 01-22-2013, 12:41 PM   #4
Do you guys think that a 16 or 18 gauge finish nailer would be okay for this, or not enough?
Old 01-22-2013, 12:44 PM   #5
You'll run the chance of the wood cupping with that small a head.
Unheated Garages: Interior or Exterior Wall Paint jsheridan Painting 24 01-17-2017 04:41 PM
Shiplap plank = hen's teeth KAdams4458 Roofing/Siding 4 10-18-2009 03:13 PM
Size/Type of Nails for Interior Framing? mfleming Building & Construction 2 09-16-2008 08:39 PM
Flashing NoExperience Painting 13 09-04-2008 05:56 AM
% total roof load on interior bearing wall? Grommet Building & Construction 1 03-29-2007 07:37 AM
