Nailing Osb To Joists? - Carpentry - DIY Chatroom Home Improvement Forum
Old 12-30-2008, 06:10 PM   #1
Rewards Points: 150
Nailing osb to joists?
I just finished cutting about a 3x5 section of my osb subfloor out and getting ready to patch it back. Had to do some plumbing and replace a water damaged section. Anyways, the one joist I have a good 3/4" to lay my osb on and the other is about a half and some spots a little less. My concern is if I need to cut a little more away to expose more of the joist to be more secure to the joist or is that enough of a nailer to go ahead and lay it on and nail it. I am anal and obsessive, just wanted to see if I was being a worry wart or to go ahead and cut a little more back before nailing it. Thx. Mike
Also: When I do my blocking for the seams I have no problems except where there is some ductwork and I can't put a piece of blocking in there. Is it sufficient enough to lay my 2x8 horizontal/flat. It's the only way anything will go in there for a nailer/block to support the cut edge of the osb. Thx.
MikeVila is offline   Reply With Quote
Old 12-30-2008, 06:51 PM   #2
Mike no problem where it's a little short stitch a 2 by 1 on the side of the joist and that will give you plenty to fasten to. On the blockers instead of nailing them screw them both sides it will stop them bouncing all over the place.Hope this helps. billy
billy d is offline   Reply With Quote
Old 12-30-2008, 07:05 PM   #3
Rewards Points: 150
Yeah that helps alot. What about where I need to block where the duct work is? Any problem with laying the block flat just for that one spot? Thx, Mike.
Old 12-30-2008, 09:58 PM   #4
Registered User
Termite's Avatar
You can add blocking to better support the seams as you see fit. Personally, I use 2x4's when they'll fit. Don't forget to use subfloor adhesive to keep the new OSB from squeaking.
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 09:06 AM
Sister or Replace Floor Joists brando1118 Carpentry 25 10-26-2008 08:43 PM
Buidling code for deck and nailing schedule Jozee Building & Construction 7 10-01-2008 12:46 PM
help with 2nd floor joists g heil Building & Construction 5 09-12-2008 06:41 PM
Best subfloor and material thickness nugentcn Flooring 7 09-07-2008 12:48 PM
