Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 11-18-2008, 09:15 AM   #1
Kellster
mjkpainting's Avatar
Nail size and Type ?????
I am doing 2X3 framing in my basement. What size and type nail should I get for my pneumatic nailer???
Also
I am attaching risers on the back of the stairs. I think I am going to use 3/4 inch plywood. What size and type of nails should I get for that.
Thanks guys
mjkpainting is offline   Reply With Quote
Old 11-18-2008, 09:43 AM   #2
Drywall contractor
I would use a 3" or 3-1/4" for the framing, 2-3/8" should be sufficient for 1"x risers.
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 11-18-2008, 09:45 AM   #3
Kellster
Thanks so much
Should I have the compressor set to a certain pressure?????
Old 11-18-2008, 09:50 AM   #4
Drywall contractor
Depends on the gun, wood type, etc. Try setting around 90 lbs. and adjust up or down if needed. Your gun may also have a depth adjustment on it for "fine tuning".
Old 11-18-2008, 09:54 AM   #5
bradnailer's Avatar
Just enough pressure to slighty sink the head of the nail. The pressure setting really depends on how much hose you have extended from the compressor.
For the stair risers, I would use deck screws and drill a pilot hole with a countersink first. However, I err toward screws over nails especially on something that might encounter slight movement like walking up and down the stairs.
bradnailer is offline   Reply With Quote
Old 11-18-2008, 10:26 AM   #6
Kellster
O.k I will do that thanks
Old 11-19-2008, 10:51 PM   #7
Get rid of the framing nailer!!! Thats my opinion. Use at least 3 " galv. nails for framing. As for stairs.....glue it and screw it.....ALWAYS!
DIYJIMBONL is offline   Reply With Quote
Old 11-21-2008, 03:06 AM   #8
knewbie
curapa's Avatar
Screw and glue the stairs for the best result. No need to go galvanized for for nailing into anything but pressure treated lumber.
curapa is offline   Reply With Quote
How to Size a Furnace super_man4471 HVAC 18 03-25-2010 10:12 AM
What type / size screws for subloor project... scheenstra Building & Construction 1 05-17-2008 09:22 PM
Wire size and type in Rigid Metal Conduit Al the Diy guy Electrical 5 02-05-2008 09:31 PM
What size nailer to use for Soffit Replacement Mach5 Roofing 2 01-28-2006 12:24 PM
Plumbing type and size marlenecapps@cox.net Plumbing 2 10-14-2005 12:42 PM
