Nail Size Recommendation - Carpentry - DIY Chatroom Home Improvement Forum
Old 12-16-2011, 07:15 PM   #1
Nail size recommendation
Connecting an 8 ft 2x4 horizontally to 3 36 in 2x4s. Also, connecting 1/2 in plywood to 2x4. Please give recommendation on the length and size nail (8d, 10d etc) for both. Also, any rules of thumb or tricks to figuring this out going forward?
Thanks,
starkhd is offline   Reply With Quote
Old 12-16-2011, 07:51 PM   #2
retired union carpenter
Send a message via Yahoo to coupe
not much information to go on. but, I typicaly use 16 penny nails to attach 2x's to other 2x's, also I use #8 penny common nails for nailing 1/2" plywood to 2x4's
as always, just my thoughts
good luck
coupe/Larry
take what helps? ignore the rest
good luck....coupe/Larry
take what helps? ignore the rest.
coupe is offline   Reply With Quote
Old 12-17-2011, 04:11 PM   #3
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,058
for all framing connections you must use a nail that is long enough to fully penetrate the first peice and a minimum of half way through the second peice.
in canada we dont use the penny system for nail sizes. it just goes by lenght. for framing we use 3 1/2" common spikes or 3 1/4" gun spikes.. and 2 1/2" common or ardox nails and 2 1/4 in the gun for putting on plywood
woodworkbykirk is offline   Reply With Quote
Old 12-18-2011, 09:11 AM   #4
here is one example of a quick search
http://www.informationdestination.ce...g-Schedule.pdf
That's just my opinion. But it's free, so take it for what it's worth to you.
1910NE is offline   Reply With Quote
Old 12-18-2011, 09:26 AM   #5
Rewards Points: 3,130
Not a definitive answer, but I have participated in a lot of Habitat for Humanity builds around the country. They frame entire houses using only 16- and 8-penny nails. I also built my own house, and that's what I did. Sure makes things easier.
Old 12-20-2011, 11:23 AM   #6
Avid DYI'er
BriBri's Avatar
Since you are not really doing a lot of 'fastening' (e.g., building a wall), I would suggest using screws on your project, especialy where it sounds like you are mounting the 8' 2x4 horizontally at only three fastening points.
BriBri is offline   Reply With Quote
Nail size Lazer Carpentry 4 04-12-2011 04:06 PM
pre-hung door, 32x80 is that door size or total size? RyanD Building & Construction 3 06-28-2009 11:33 PM
Room size X floor tile size deck hand Flooring 4 04-08-2009 05:42 PM
What size nailer to use for Soffit Replacement Mach5 Roofing/Siding 2 01-28-2006 12:24 PM
