Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 08-14-2012, 08:05 AM   #1
Nail holes in particle board
One of the doors on a kitchen cabinet was ripped off and now the holes (where the screws were) are too big to put the screws back in. If I fill the holes, can I rescrew the screws back in the same place to affix the cabinet door?
MaryDennett is offline   Reply With Quote
Old 08-14-2012, 08:09 AM   #2
yes you can.
Old 08-14-2012, 08:54 AM   #3
Originally Posted by DannyT View Post
yes you can.
Depends what she fills it with. Plastic/chemical wood will work, anything else might not!
tony.g is offline   Reply With Quote
Old 08-14-2012, 09:45 AM   #4
I would probably dowel them; drill a hole, apply glue, tap the dowel in place, let the glue dry, and cut it off flush. You can buy small packages of dowels at your local lumber yard, hardware, or big box.
Carpet over Particle board ford2fast9 Remodeling 3 04-11-2011 12:48 PM
particle board question??? Axhammer Flooring 27 01-04-2010 08:08 PM
Right product to fill finishing nail holes? yummy mummy Building & Construction 14 11-06-2008 09:16 PM
Particle board underlayment help diynut Flooring 5 03-07-2006 06:22 AM
particle board / hardibacker fish3211 Flooring 4 08-10-2005 09:32 PM
