Nail Gun For Wainscoting - Carpentry - DIY Chatroom Home Improvement Forum
Old 03-27-2013, 12:07 PM   #1
Nail Gun for wainscoting
I'm going to be installing some wainscoting and crown molding in a room and am a beginner so I probably won't be using the nail gun a whole lot. So I'm hopefully going to keep the nail gun price under $150. Below are three nail guns I was thinking about getting. I'm not sure what gauge I should go with I like the 15 gauge gun since it's angled and I've read online that I want an angled gun but I wasn't sure if the nails would be to big. I couldn't find many angled guns that were 16 or 18 gauge. Please reply back and let me know which of the three guns you think I should go with or just reply back with the gauge you think I should use for wainscoting or crown molding. Any help would be appreciated.
15 gauge
http://www.amazon.com/Factory-Recond...pr_product_top
16 gauge
http://www.amazon.com/Factory-Recond...l+Gun+16+gauge
18 gauge
http://www.amazon.com/Hitachi-NT50AE...l+Gun+18+gauge
bsmith95610 is offline   Reply With Quote
Old 03-27-2013, 12:32 PM   #2
Jack of all - master none
hyunelan2's Avatar
Rewards Points: 686
The 18g brad nailer might be a little small for some things. I use my little 18g for things like picture frame molding or other very small or more-delicate pieces. For most trim and crown work, the 16g finish nailer is what I use. I've never had an "angled" finish nailer, but never had any problems with the straight nailers I've used either. Wait for someone with more experience to speak on the merits of those two.
hyunelan2 is offline   Reply With Quote
Old 03-27-2013, 12:37 PM   #3
Roofmaster
Rewards Points: 2,172
I have a Hitachi NT65MA2 for general finish work. Angled, takes up to a 2.5 inch 15 Gage nail. I also have a Hitachi 1/4 inch stapler which is very handy. I bought them both as recons, but they were new for all intents and purposes. I use and love them both, I use super lube air tool lube in both. no problems at all.
Old 03-27-2013, 02:46 PM   #4
After doing some more reading online now I'm thinking of going with the 16 gauge since some people say an 18 gauge isn't strong enough and some people say a 15 gauge will work but will leave large nail holes and may split the trim. So does it matter that the 16 gauges are not angled?
Old 03-27-2013, 03:02 PM   #5
Roofmaster
I suggest that you look at the actual difference between 15 and 16 gage. It is miniscule. Splitting is more a function of how close you nail to the end of the board. I don't nail closer than about 3 inches. The angled feature is important when you are working in corners like crown and dental molding. Since both are available, why not get the one that is angled?
Old 03-27-2013, 08:38 PM   #6
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,058
15 gauge has more holding power where the nail has a head on it. this is very important for exterior trim where the material is subject to weather and seasonal temperature changes.
for interior work 16 gauge is all thats needed.. it wont split the wood as the nails have a chiseled tip so they punch through the material .. the same will happen with hand nails if you blunt the end by hitting it with a hammer before driving it. angled guns are less finicky than straight ones.. the trick is to actually find one though.. locally no one sells angles 16 gauge guns even the tool dealers...
woodworkbykirk is online now   Reply With Quote
Old 03-28-2013, 01:31 AM   #7
Now I'm thinking I'm going to get this 16 gauge nail gun. It has good reviews and is cheap $51 and I won't be using it to often. I didn't have much luck finding a 16 gauge nail gun for a good price that was angled. Let me know if you think I should not get this one for some reason.
http://www.homedepot.com/p/t/2021017...8#.UVPjrRy-1Bl
Old 03-28-2013, 05:35 AM   #8
I know alittle about alot
JWilliams850's Avatar
whatever floats your boat
JWilliams850 is offline   Reply With Quote
Old 03-28-2013, 06:09 AM   #9
Rewards Points: 13,250
Will that work yes, will you be able to get it fixed localy if it breaks?
A brand name tool would be far more likly to be fixed.
http://www.reconditionedtools.com/fa...inish%20nailer
Old 03-28-2013, 09:01 PM   #10
Davejss's Avatar
Rewards Points: 740
I use a 15 gauge angled finish nailer for most of the trim, and my little brad nailer to pin the miters and thin edges.
Davejss is offline   Reply With Quote
Tags
crown molding , nail gun , wainscoting
Me ranting about nails... Pittsville Building & Construction 14 10-05-2012 01:26 PM
Nail gun shock injuries dswan388 Safety 5 06-17-2009 01:21 PM
Nail gun shock injuries dswan388 Roofing/Siding 11 11-24-2008 07:34 PM
Nail gun shock injuries dswan388 Tools 5 11-02-2008 09:46 PM
Nail Gun Plastic Nail Casing frustrations smark General DIY Discussions 6 07-07-2008 09:10 PM
