01-29-2013, 06:41 PM
#1
Nail Gun Problems
So i bought a harbor freight framing nailer for my home remodel.
http://www.harborfreight.com/air-too...ler-69927.html
And here is the compressor I'm using.
http://www.lowes.com/pd_103500-43657...t_avg_rating|1
So i got to the point in my project where i needed to use the nailer but I'm having problems with the gun not driving the nails all the way in.
I adjusted the depth gauge to the deepest setting but it still only drives a 3inch nail about 2 inches in.
This is the first time i have ever used a nail gun so I'm not sure if I'm doing anything wrong.
I let the compressor fill to max pressure and set the attachment pressure to 100psi which is the recommended pressure.
Could it be that the compressor is too small? Or a bad nail gun?
Any help is appreciated. Right now I'm using a palm impact nailer to work with which is fine but i wanted to get to use the nail gun.
Any help is greatly appreciated!
01-29-2013, 07:00 PM
#2
Nail Gun Problems
My first thought is the compressor. It only goes to 100 pounds. Then you add a 50' hose and it may bee 100 at the compressor, will be a lot less at end of hose.
Now the framing gun says it will work at 70 psi, and should be close if your compressor is fully filled, if you shoot a couple nails, will be below the 70 psi at end of hose.
The average contractor compressor to run a nail gun will go to 120 psi, Anything less in my mind is to pump up bicycle tires with.
I bought a cheap air compressor at shucks one time for $99.99, and it really whizzed me off because it worked fine for nail guns and lasted 5 years before it ran out of oil and died.
Was made out of cast iron and heavy to carry from truck to house and heavier if working on second floor.
A cheap air compressor is fine and will work, but need the 120 psi, I bought the porter cable and goes to 150 psi.
But I have no clue on the quality of that gun, if not sinking any nails, even with first couple before air pressure goes down .... it is indication that it needs more air, but with that brand more air may not help.
If it was easy, we would not call it work!
The Following User Says Thank You to funfool For This Useful Post:
01-29-2013, 07:29 PM
#3
journeyman carpenter
Nail Gun Problems
most tools will say a recommended pressure to run throgh them, finish guns are said to be run at around 80-90 psi and framers at 90 -100.. i keep my compressor at 110 for running both types of guns, then simply use a different thickness hose. 1/4 " hose for trim guns, 3/8 for coil nailers and framers.. the smaller hose doesnt let as much air through. this should be sinking your nails now.. if the gun kicks back violently you have too much air. then dial it down
01-30-2013, 01:36 AM
#4
Nail Gun Problems
I have a Senco nailer, I run mine around 120, it will still generally nail flush at as low as 90 pounds but not always.
I am willing to bet it is a combination of somewhat lower quality gun and not quite enough pressure.
Have you oiled your gun?... It likely will have come with pnuematic oil, if not, go get some at the hardware store and try oiling it, it may or may not help. When you oil it just drop the oil into the air fitting a few drops will do. Whatever you do, do not try using WD40 or other types of oils, they can ruin the gasketts in the nailer.
LOL..... okay, I just saw the pic of the air compressor.... air compressor all the way. I bought a near identical one to that for my wife to use the air stapler and air brad nailer with.... I couldn't even get them to actuate with it let alone actually staple or nail anything. We now use that one for airing tires and for cleaning the mill.
This one will drive your gun quite nicely, they are fairly cheap and the thing I like is that they are not real big and heavy. http://www.ebay.com/sch/Air-Compress...air+compressor I have two of these and am impressed with them, not near as good as my big (supposedly portable)compressor but they are also about 150 pounds lighter.
01-30-2013, 01:44 AM
#5
Nail Gun Problems
It's not the pressure that the issue.
That compresser has less then .3 CFM at the pressure your running.
The gun needs at least 3.0 CFM
Notice the position of the .
Bring up the spec. on the tools he posted.
01-30-2013, 02:35 AM
#6
JOATMON
Nail Gun Problems
I'm thinking....the HF might be the issue....
If you have the pressure at the right level.....when you pull the trigger....it already has the volume you need....the hose only limits how fast it can recharge.
Common Sense is like Deodorant. Those that need it the most don't use it.
My To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. ... To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. and To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
01-30-2013, 07:31 AM
#7
Super Moderator
Nail Gun Problems
Compressor is to small
01-30-2013, 08:01 AM
#8
gravity always wins
Nail Gun Problems
If the compressor has pumped up to at least 100 pounds and shut off, then the size of the pump (.36 SCFM) is irrelevant. You've got 2 gallons of compressed air at pressure to drive the nailer at least once, possibly more depending on the air requirement of the tool. The recovery time for the compressor will affect how many nails you can drive before you are stuck waiting for the compressor to catch up. That is where the SCFM number comes into play. The pump fills the tank. The tank drives the tool. Be sure your air hose is flowing the proper amount of air. A torn liner inside of a hose will restrict flow. I've just got to mention. Be sure you are reading the line pressure gauge and not the tank pressure gauge.
01-30-2013, 08:03 AM
#9
Super Moderator
Nail Gun Problems
He may be trying to use the tiny hose that comes with the tiny compressor---
01-30-2013, 08:13 AM
#10
gravity always wins
Nail Gun Problems
I can't imagine that you'll get more than a couple of nails out of that set up before you'll wait a long time for the compressor to catch up. You'll run that little thing into the ground, but it should at least drive a nail or two, so the compressor pump is not the initial problem. Air delivery may be.
The Following User Says Thank You to Maintenance 6 For This Useful Post:
01-30-2013, 08:24 AM
#11
Super Moderator
Nail Gun Problems
Simple enough to figure out---oil the gun--then try it on a known ,good compressor---If you don't have a friend with a compressor---
Take the gun,nails and a board to your regular auto mechanic---have them give it a try on their big compressor----mechanics like to play with someone else's toys ----I know mine would any way---
01-30-2013, 09:09 AM
#12
Nail Gun Problems
Thanks for all the tips guys!
I'm going to try and return the gun and get a better quality one and see. I was thinking even with that small compressor that i should able to get a few shots off before it empty's the tank but i'm fine with that because the project is not THAT big.
If its still a problem i guess i will take the compressor back and exchange that as well. Can anyone push me in the right direction as far as size and psi that i should look for?
Thanks Again!
01-30-2013, 09:12 AM
#13
Nail Gun Problems
What are you trying to nail into?
01-30-2013, 09:15 AM
#14
Nail Gun Problems
Just regular 2x4 studs into floor joists.
01-30-2013, 12:10 PM
#15
Roofmaster
Nail Gun Problems
I bought a cheap air compressor at shucks one time for $99.99, and it really pissed me off because it worked fine for nail guns and lasted 5 years before it ran out of oil and died.
Why did it whiz you off when YOU let it run out of oil? I change the oil in my AC once a year. You never checked yours?????
" A lot of men build things, and a lot of things fall down "
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
