At my wits end.....
I have a slight problem. I am trying to cut chair molding to go around the ceiling in my living room. Sounds easy enough. Unfortunately I have a vaulted ceiling so the cuts have to be both 45 degrees and 20 degrees to match up with the ceiling. The problem is when I make the 20 degree cut it never matches up with the straight cut piece at 90 degrees. Is this cut even possible or should I just give up and sell the house??? Any help would be greatly appretiated. Thank you.
This has been discussed recently. A quick search will bring up the thread, in the meantime here is a link http://www.garymkatz.com/TrimTechniq...ansitions.html
That link is all well and good but I am not using crown molding. I am using chair rail that sits flat against the wall.
You are missing the essence of the article. In order to transition from level to rake using the same profile a transition piece is needed. The transition can be made without a transition piece, however the rake molding will need to be a different size than the level molding. The amount of the change in size is determined by the angle of the rise. Here is a link which may explain it more fully http://www.thisiscarpentry.com/2010/...board-returns/
two angles will never join up to meet properly unless they are equal, but there's no way to do that around a corner like that without a transition piece as posted above.
Ron |
I just had total knee replacement surgery last week, but I'm feeling more pain from some of these threads than I am from my knee!
Its a compound cut, the moulding is sitting flat, you can't divvy up the 20* to make them two 10's. You have to transition them as was originally suggested. Are we getting too anal with our answers lately? |
| All times are GMT -4. The time now is 05:12 PM. |
