#1 |
Are my windows installed wrong?
I just moved into a home with most of its windows replaced, however they left the finishing to me -- the new owner. So there are no exterior or interior trims.
..the new Andersen windows replaced bigger windows, so whoever installed these had to build up the surround (with 2x4's, drywall, insulation, exterior siding, etc) so that the new (smaller) windows would fit. The problem is it appears that they installed the windows AFTER they built up the exterior. So the exterior siding of the house (boarding) is underneath the metal casing of the window, ie. you can see the nail heads. My question is, isn't this a wrong way to install windows? Do I have to redo all these installs (over 10)? Or is this an ok lazy technique of installation -- and I should just finish the trim? Also on the inside the jamb extensions are like ~1 inch too short as a result of the window depth being pushed out by the depth of the siding. Thanks in advance! Link to photos: http://picasaweb.google.com/bogamils...eat=directlink |
#2 |
Thise windows are ready for sding to be installed up to them. The flange with the nails is definitely supposed to be UNDER the siding.
Do not PM with questions that can be asked in a forum. I will not respond. |
#3 |
Custom Cabinet Maker
Find that builder and installer, drag em out to the house, shove a stick of Dynamite as far as you can, put a 3' fuse on it and light it. They have until that fuse burns down to get it fixed.
![]() Oh Yeah they pay for the new siding also. I am serious, I would most likely have a lawyer on standby Last edited by skymaster; 04-30-2009 at 01:35 PM. Reason: nudder comment |
#4 |
Whatamess
Need to install "J" channel around the window before siding.
I may go home hungry, but not tired and hungry. |
#5 | |
Are my windows installed wrong?Quote:
I know its hard to tell because of the dark color/photo, but the siding is underneath the tar paper. Best to see in the 3rd pic. Stupid huh? So it looks like I have to redo the installs... 10+ windows, yuck. |
#6 |
Newbie Bill
Didn't you have the home inspected before you purchased it?
That screw up should have been really obvious and shouldn't fall onto your shoulders to fix. |
#7 | |
Part of the joys of a short sale. I got a good deal, just have to work through the projects. I just wanted to make sure I (or someone I hire) finish these windows right. |
#8 |
Chicago, IL
Are my windows installed wrong?![]() Go here: http://web.pella.com/supportcenter/i...tructions.aspx and click on any of the links to double hung windows for details of a typical installation.
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Last edited by Michael Thomas; 04-30-2009 at 08:10 PM. |
#9 |
Newbie Bill
Are my windows installed wrong? |
#10 | |
Oldie but Newbie
![]() Maybe he was going to re-side or stucco it. ![]() It looks like they pretty much ignored the flashing tape, too.
#11 |
Thanks for the replies, I'm going to contact someone to redo these things.
How much should I expect per window if I ask for re-installation and exterior trim? |
#12 |
Could be the previous owner had planned to side over the old siding and the windows. It is missing the flashing tape if that's the case. I've seen worse.
#13 |
My first question would be; "Are the 10 or so windows installed exactly like the ones shown in the picture?
Because I can tell you that, when a house has existing shiplap siding boards or the dreaded T-111 junk, unless the windows are installed prior to the siding going up, reinstalling these will be an nightmare. well....not really. First of all, if you do have someone re-do these, here are the challenges.
Good Luck!
A great personality will open many doors in life, but it's your character that keeps them open! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. "Where Every Nail Has a Purpose!" |
#14 | |
Thanks for your input, it's very helpful. The siding is reverse board and batten. And yes all 10 are installed like this. I would have to get new plywood siding and cut to fit the perimeter of each window and seal the seams where the filler pieces butt up against the existing siding, right? That would mean if you were up close you could see a rectangular seam in the siding around each window. The other thought that came to mind is to rip off the adjacent pieces of siding as a whole and cut the new 4x8 sheets to fit the new window size. Is that even possible with the overlap installation of these boards. I'm not sure I understand the narrow trim detail limitation because of the stud and jack stud width. How wide can you go with a non debacled window install and why? |
#15 |
Chicago, IL
IMO as a practical matter you are going to be able to get away with murder in terms of weather-tight installation of the windows under the porch, they are primarily a cosmetic problem.
You're going to have bigger problems with windows in exposed locations, don't know what your budget is like, but at rehabs of my own rental property I've sometimes found it simpler just to bite the bullet and re-frame slightly oversize, in the end I got a much more satisfactory result both aesthetically and likely in terms of long-term performance. Home Inspection: "A business with illogically high liability, slim profit margins and limited economies of scale. An incredibly diverse, multi-disciplined consulting service, delivered under difficult in-field circumstances, before a hostile audience in an impossibly short time frame, requiring the production of an extraordinarily detailed technical report, almost instantly, without benefit of research facilities or resources." - Alan Carson
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
| Display Modes | |
| Harvey Windows or Certainteed Bryn Mawr II ??? | mike1975 | Remodeling | 5 | 04-02-2009 09:40 AM |
| terrible windows | mt232 | General Discussion | 10 | 12-28-2008 06:37 AM |
| Thermal Barrier Windows vs Vinal Windows | MeraleeCrowl | Remodeling | 6 | 11-05-2008 05:46 PM |
| Basement windows above floor joists | billthecat | Building & Construction | 7 | 10-20-2008 09:07 AM |
| new windows | juliejules4 | HVAC | 12 | 12-06-2006 02:37 PM |
