Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 09-28-2009, 08:07 AM   #1
Sephora's Avatar
My doors stick...I need ideas.
What can I do to make my front and back doors from sticking when I close and try to open?
We painted both doors recently and I didn't go on the edges, I just left them natural. They door stick now!
I know the weather makes the wood shrink and widen but now that it is cool I think it might be some piant that might of gotten on the edges.
What do I do? Oil? Sand?
It is so loud to open my front door I nearly wake up my toddler each morning!
Sephora is offline   Reply With Quote
Old 09-28-2009, 08:31 AM   #2
Remodeler
MinConst's Avatar
Try just waxing around the edges with paste wax. If it is the paint that is sticking this should solve the problem.
Minichillo's Construction
I will never leave you hanging!
MinConst is offline   Reply With Quote
Old 09-28-2009, 08:58 AM   #3
Sephora's Avatar
Ahhh. thanks. Where do I get this paste wax?
Old 09-28-2009, 09:35 PM   #4
Household Handyman
The paste wax is a good long term solution. In the meantime, you can use bar bath soap to rub on the edges of the door itself, one edge at a time to see which edge is sticking. Actually, you could rub the soap on maybe the top fourth of the door edge, try that, and if that is not the area, try the next fourth of the door edge. This way you will find the sticky area quickly. A good paste wax can be found at most big box stores in the wood finishing area. Good Luck, David
Old 09-28-2009, 10:14 PM   #5
Tom Struble's Avatar
you should finish all the edges of wood doors,they will always keep warping
Tom Struble is offline   Reply With Quote
Input on which doors to replace interior & exterior door with... tomas21 Carpentry 13 12-08-2009 10:32 AM
Interior door swelling? jdeters79 Remodeling 9 08-15-2009 11:51 AM
Installing closet doors into un-true opening - Need ideas McCool Carpentry 8 08-12-2009 02:37 PM
UGH! A lesson for new Pre-Hung Doors javan General Discussion 6 08-08-2008 08:47 PM
It's hot outside. Keep the exterior doors and windows closed if running the A/C? Taylor Crockett HVAC 3 07-07-2008 06:04 PM
