Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 10-26-2010, 09:22 PM   #1
moving window sash
how can I fix a caradco sash that won't stay up on its own???
bftjr1944 is offline   Reply With Quote
Old 10-26-2010, 11:13 PM   #2
moving window sash
There are 2 counter balances on each sash. One or both of yours is broke or disconnected. Tilt the sash in and remove it from the frame and look at the balances. If you can't see the problem, remove a sash that works properly and compare them. Pay close attention to the removal process or another sash will have issues.
It could be a simple issue of the sash not being put back correctly and not engaging the balances.
Ron
How to disassemble aluminum clad wood window sash? JohnBinSC General Discussion 6 01-17-2011 06:59 AM
window sash replacement kits? jimhome Remodeling 5 11-02-2009 01:48 PM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 06:11 PM
Window sash runner/liner jds1900 Remodeling 3 04-26-2009 09:35 PM
Replacing window sash with rotten bottom jandrew Carpentry 3 08-31-2008 05:02 PM
