Moving Studs In Load Bearing Wall - Carpentry - DIY Chatroom Home Improvement Forum
Old 02-19-2007, 09:30 PM   #1
Moving studs in load bearing wall
I am building a home theater in my basement and want to take advantage of the dead space under the staircase to store my audio rack. When I removed the drywall I found several studs that will need to be moved. I need to create a 22" opening to insert my audio rack in.
My plan is to remove the two studs to 22" apart to enlarge the hole. I am also planning to install a double 2X6 header at the top and remove the bottom plate as the rack will roll in and out of this space. Does this sound reasonable?
I have attached a picture of the damaage so far
Any thoughts would be appreciated.
Beermoney is offline   Reply With Quote
Old 02-20-2007, 04:53 AM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Go for it,
If that staircase is framed properly, then those studs are not supporting anything, but are there for the sheetrock to be attached to.
In other words, that should not a load bearing wall....
Check to make sure that the stairs are properly attached at the top where the stringers meet the floor joists.
- Build Well -
Old 02-20-2007, 08:38 PM   #3
Thanks. I will take a look to see if the stringers are attached at the top of the stairs. I was concerned becasue there is a set of 4 studs on the right (only two are showing). Would they have put 4 studs in one place just to hang sheetrock?
Thanks again for thr reply.
Old 02-20-2007, 08:59 PM   #4
Check those out. I saw that in your pic (the double studs on the right) ...that is why I suggested that you look at and examine how your stair case is supported...
There is the right way...and then, every now and then, ...sadly...the wrong way.
Example: We recently got called in to finish up a new construction home this past November. The area to be finished off was the entire 2nd floor and the stair well leading to it. The stairwell was located in the breezeway structure between the garage and the residence...
I have NEVER seen a stairway built like this in my life...UGH.
The HO had a dear friend who built it ....(She called him a: "Handy man and Master Carpenter")
...Unfortunately, the Local Town Building Inspector didn't agree with that title when he rejected the stair case build and even wrote on the permit: "Terrible Work"....
...She later found the 'alleged'.... "Master"...... 'cracked out' , deep in the woods, in back of the house .... and subsequently fired him....
Anyways.....That is why I say to check and see how the stairwell was supported (you never know exactly how they were actually built and supported)....Regarding your design with the header....You should still be able to do what you want to do. I think that your idea to basically install Jacks & kings...may be a good precautionary method....Those stairs are all the weight involved that you need to support (you are not supporting floors above). The stringers supports all the horizontal and diagonal weight load of the stairs, so there is no need to install a structural type header, tho, a normal opening type header would be standard for such an opening....
- Build Well -
Old 02-21-2007, 07:43 AM   #5
OK. That makes a lot of sense.
Thanks a lot!
BM
% total roof load on interior bearing wall? Grommet Building & Construction 1 03-29-2007 07:37 AM
moving another load bearing nailfun Carpentry 2 02-20-2007 08:10 AM
Load Bearing Wall? Traybae Remodeling 3 11-05-2006 01:39 PM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 01:01 PM
Load Bearing Wall rpatterson Building & Construction 2 10-29-2005 07:43 AM
